ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2008-04-28T19:45:23+01:00https://brainmodular.org/forums/app.php/feed/topic/8102008-04-28T19:45:23+01:002008-04-28T19:45:23+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4221#p4221Note that this 'all notes off' is logical, I'm OK with it and you should keep it. It is NOT a ghost. But it is unnecessary - and very bothering - to send it as long as the synchronisation is of. Only one cc123 should be fine?
Statistics: Posted by Vincent — 28 Apr 2008, 20:45
The 'seq midi' module is only maintained for backward compatibility. Use the Piano roll instead. The CC123 is 'all not off'.
Thanks Olivier. OK, but the 'Seq midi' automaticly comes up when a midi file is drop in the sequencer (UsineProStandAlone3.63c).
PS : Yes, I now well know what cc123 is!
Statistics: Posted by Vincent — 28 Apr 2008, 17:52
]]>2008-04-28T09:01:29+01:002008-04-28T09:01:29+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4217#p4217The CC123 is 'all not off'. Maybe the 'Seq midi' is buggy now, but I'll not spend time on this module, since the pianoroll does a better job.
ok , i've test your way : insert a midifile in the sequencer , add a midi in module...no problem maybe check the midifile itself...? or try with an other midifile..?
The same for all of them. I made them: there is no cc123 in the CC I use! I think it just comes when Sync is OFF, I'm working on that right now. This idea of sending a cc123 when the sync goes OFF seems logical, but I think that there's no need to send it continuously (repeated), once would be enough...
Statistics: Posted by Vincent — 27 Apr 2008, 22:44
]]>2008-04-27T21:32:33+01:002008-04-27T21:32:33+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4214#p4214ok , i've test your way : insert a midifile in the sequencer , add a midi in module...no problem maybe check the midifile itself...? or try with an other midifile..?
Statistics: Posted by nay-seven — 27 Apr 2008, 22:32
sorry , i've replicate your patch with an other vsti , insert it in sequencer and no problem here...
Thanks for help, Yan, why to be sorry? No Vista here for the moment, but XP pro. No matter I think. One difference is that I first inserted the patch in the sequencer, since it's a midi file, and then change the patching. Doing your way (not in sequencer for patching), I just noticed a detail: the Piano Roll sends this cc123 only when Sync is OFF. Seems to be necessary to prevent hanging notes when switching Sync OFF. Any idea to bypass this inconvenient?
Statistics: Posted by Vincent — 27 Apr 2008, 22:19
]]>2008-04-27T20:50:20+01:002008-04-27T20:50:20+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4211#p4211i'm under vista sp1...?
Statistics: Posted by nay-seven — 27 Apr 2008, 21:50
]]>2008-04-27T19:48:49+01:002008-04-27T19:48:49+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4210#p4210Try just to put a 'Midi Filter' after the 'Midi Seq' and it shows that the cc123 sends non stop (red led "send" always lit)... with nothing before. I always hated ghosts, specially #123!
Statistics: Posted by Vincent — 27 Apr 2008, 20:48
]]>2008-04-27T19:37:23+01:002008-04-27T19:37:23+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4208#p4208and controller 123 is " all notes off " so maybe normal but where did this controller came from...? seems like you have a ghost here
seriously , maybe active the "trace in " in your midi in setup..?
Statistics: Posted by nay-seven — 27 Apr 2008, 20:37
Default patch (almost...) with upstream midi mixing: Downstream midi mixing: Since the 'seq midi' sends a cc123 continuously, the VSTi cannot be played via the Midi In... except very strange percussions! My question is: how to make it work this way? (or stop this cc123) I hope I'm less confuse... Thanks! V
Statistics: Posted by Vincent — 27 Apr 2008, 17:53
]]>2008-04-27T15:56:46+01:002008-04-27T15:56:46+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4205#p4205could you explain (for a midi newbie like me...)
]]>2008-04-27T15:45:35+01:002008-04-27T15:45:35+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4203#p4203Statistics: Posted by Vincent — 27 Apr 2008, 16:45
2008-04-26T15:36:14+01:002008-04-26T15:36:14+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4196#p4196In a MIDI patch, in sequencer mode, why is it not possible to mix MIDI downstream from the 'seq multi'? It sends continuously a CC123 that cannot be filtered by a 'midi filter' set to 'ON/OFF/BEND' but by at least three 'midi filter' respectively set to 'NOTE ON', 'NOTE OFF' and 'PITCH BEND' (plus eventualy a CONTROL CHANGE, plus...). Do all the MIDI mixes have to be upstream from the 'seq multi' ? Thanks!
Statistics: Posted by Vincent — 26 Apr 2008, 16:36
]]>BrainModularBrainModular Users Forum2008-04-28T19:45:23+01:00https://brainmodular.org/forums/app.php/feed/topic/8102008-04-28T19:45:23+01:002008-04-28T19:45:23+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4221#p4221Note that this 'all notes off' is logical, I'm OK with it and you should keep it. It is NOT a ghost. But it is unnecessary - and very bothering - to send it as long as the synchronisation is of. Only one cc123 should be fine?
]]>2008-04-26T15:36:14+01:002008-04-26T15:36:14+01:00https://brainmodular.org/forums/viewtopic.php?t=810&p=4196#p4196In a MIDI patch, in sequencer mode, why is it not possible to mix MIDI downstream from the 'seq multi'? It sends continuously a CC123 that cannot be filtered by a 'midi filter' set to 'ON/OFF/BEND' but by at least three 'midi filter' respectively set to 'NOTE ON', 'NOTE OFF' and 'PITCH BEND' (plus eventualy a CONTROL CHANGE, plus...). Do all the MIDI mixes have to be upstream from the 'seq multi' ? Thanks!
