ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-01-24T22:31:24+01:00 https://brainmodular.org/forums/app.php/feed/topic/78 2007-01-24T22:31:24+01:00 2007-01-24T22:31:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=1074#p1074 <![CDATA[Aux tracks]]>
Just to aswer Gybe: to set up your reverb in the AUX1 bus, simply create a patch "audio in -> reverb -> audio out" on a track then set the input of this track to AUX1 (and of course the output of the track to your main out).
Ok, so that's how it works ! ... I get it now. I had just found how to use the "send to audio/data" stuff that works fine too
Thanks for your help...sadly more questions to come but in another topic !
Statistics: Posted by Gybe — 24 Jan 2007, 22:31
2007-01-24T22:25:28+01:00 2007-01-24T22:25:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=1073#p1073 <![CDATA[Aux tracks]]>
Just some thoughts about AUX buses.
I think two AUX (like it is now) are a good number (in a matter of CPU and screen real estate saving).
Personnally I use a lot the "send to audio or midi bus - get from audio or midi bus" modules to add Aux buses when more than two needed, these modules allow really crazy routing.
Also I use the "additional audio in - (out)" modules to do some "hardware aux busses": for example
Track 1: input set to AUX1 - output set to OUT1 (my master out),
then on this track a patch with:
"audio in" -> "additional audio out" (set to an output of my sound card linked for instance to a hardware FX)
then "additional audio in" (set to an input of the soundcard receiving the hardware FX) -> "audio out"
Then any other track can easily send to track 1 via the AUX1 Fader.
Rgds,
B.
Statistics: Posted by bmoussay — 24 Jan 2007, 22:25
2007-01-24T19:38:19+01:00 2007-01-24T19:38:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=1072#p1072 <![CDATA[Aux tracks]]>
I understand what is said above and I want to use the same example with the reverb :
- I use a sampler patch on my 2 first tracks
- I want to add a general reverb to them thru Aux buses so I use the aux 1 fader to adjust the level of sound for track 1 and 2
Question is...where do I add my reverb patch ? How do I "edit" Aux 1 ?
I just d'like to know where to find them...but maybe it comes from the free version I use.
Thanks for your help and sorry for being such a bother but I'm still experimenting under Usine (it's been 2 weeks now).
Statistics: Posted by Gybe — 24 Jan 2007, 19:38
2006-06-07T08:38:57+01:00 2006-06-07T08:38:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=389#p389 <![CDATA[Aux tracks]]> Statistics: Posted by senso — 07 Jun 2006, 09:38
2006-06-06T23:48:51+01:00 2006-06-06T23:48:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=388#p388 <![CDATA[Aux tracks]]> Statistics: Posted by lvr — 07 Jun 2006, 00:48
2006-06-06T20:49:47+01:00 2006-06-06T20:49:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=380#p380 <![CDATA[Aux tracks]]>
There are only 2 aux busses.
I know, it's a limitation but, we have to take care about the CPU load. (Everything as a cost...)
For more funky routing you can use: the global constant module.
Statistics: Posted by senso — 06 Jun 2006, 21:49
2006-06-06T12:14:47+01:00 2006-06-06T12:14:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=370#p370 <![CDATA[Aux tracks]]>
at present i select the "aux" input for a track that i want to work as an aux...is it the way it is supposed to work?
Same question as Lalo. I do the same way. Is this the way it is supposed to be done ?
Statistics: Posted by lvr — 06 Jun 2006, 13:14
2006-05-21T12:23:51+01:00 2006-05-21T12:23:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=317#p317 <![CDATA[Aux tracks]]> thanks,
luca
Statistics: Posted by unguitar — 21 May 2006, 13:23
2006-05-17T09:22:00+01:00 2006-05-17T09:22:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=274#p274 <![CDATA[Aux tracks]]>
6 aux busses? :)
as my mackie mixer? :)
Statistics: Posted by lalo — 17 May 2006, 10:22
2006-05-17T09:16:58+01:00 2006-05-17T09:16:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=271#p271 <![CDATA[Aux tracks]]>
You send audio from any track to the aux1 (or 2) and then create a new track with aux1 (or 2) as input.
Typically:
you put a reverb effect on a track with the aux1-2 as input.
You send the sound from other tracks to the reverb by adjustement of the aux1-2 fader of each track.
hope i'm clear...
Statistics: Posted by senso — 17 May 2006, 10:16
2006-05-17T08:48:06+01:00 2006-05-17T08:48:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=78&p=266#p266 <![CDATA[Aux tracks]]>
i didn't not well understand the aux tracks...
how to create explicitly one?
Statistics: Posted by lalo — 17 May 2006, 09:48
Rgds,
B.
luca
6 aux busses? :)
Typically:
hope i'm clear...
