ArrayArray BrainModular BrainModular Users Forum 2026-11-04T19:33:52+01:00 https://brainmodular.org/forums/app.php/feed/topic/7480 2026-11-04T19:33:52+01:00 2026-11-04T19:33:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=7480&p=46478#p46478 <![CDATA[Re: New SDK available]]> I'll look into that right away !
Thanx !
Statistics: Posted by oli_lab — 04 Nov 2026, 19:33
2026-11-04T10:04:44+01:00 2026-11-04T10:04:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=7480&p=46476#p46476 <![CDATA[New SDK available]]> https://github.com/brainmodular/USINE-SDK-PUBLIC
CODE:
### Latest changesSDK 703003 changes the way a module describes itself and creates its parameters.A module written for the previous version (702002) builds again after the steps 1 to 3.The steps 4 to 6 move it to the new way of writing a module, followed by every example.The [release notes](RELEASENOTES.md) list all the changes.**1. Compile in C++20.** The SDK now uses designated initializers.Set *C++ Language Standard* to *ISO C++20 Standard (/std:c++20)* in Visual Studio,*C++ Language Dialect* to *C++20* in Xcode.**2. Remove your `GetBrowserInfo`.** The SDK implements it in `UserModule.cpp` from your`MODULE_NAME`, `MODULE_DESC` and `MODULE_VERSION` constants: if your module still defines it,the link fails. The SDK also sets `Name`, `Description` and `Version` before calling`onGetModuleInfo`, remove these lines from your `onGetModuleInfo` too.**3. Check the new global names.** `UserDefinitions.h` now includes `UserError.h`, which declares`Level`, `Verbosity`, `Error`, `errorList`, `RegisterError`, `traceType`, `sdkRaiseError`,`setVerbosityLevel` and `current_verbosity_level` in the global namespace.Rename what clashes in your module.**4. Describe the module in `ModuleDefinition.h`, and create the parameters in `onCreateParameters`.**Each parameter is an `inline constexpr TParamInfo`, created and bound to its event by `sdkCreateParam`.Before, with SDK 702002:```cpp// MyModule.cppconstexpr AnsiCharPtr UserModuleBase::MODULE_NAME    = "my module";constexpr AnsiCharPtr UserModuleBase::MODULE_DESC    = "what my module does";constexpr AnsiCharPtr UserModuleBase::MODULE_VERSION = "1.0";constexpr NativeInt GAIN_CBID = 0x00100000;void GetBrowserInfo(TModuleInfo* pModuleInfo){    pModuleInfo->Name        = UserModuleBase::MODULE_NAME;    pModuleInfo->Description = UserModuleBase::MODULE_DESC;    pModuleInfo->Version     = UserModuleBase::MODULE_VERSION;}void MyModule::onGetModuleInfo(TMasterInfo* pMasterInfo, TModuleInfo* pModuleInfo){    pModuleInfo->Name           = MODULE_NAME;    pModuleInfo->Description    = MODULE_DESC;    pModuleInfo->Version        = MODULE_VERSION;    pModuleInfo->ModuleType     = mtSimple;    pModuleInfo->NumberOfParams = 1;}void MyModule::onGetParamInfo(int ParamIndex, TParamInfo* pParamInfo){    if (ParamIndex == 0)    {        pParamInfo->ParamType    = ptGainFader;        pParamInfo->Caption      = "gain";        pParamInfo->IsInput      = TRUE;        pParamInfo->IsOutput     = FALSE;        pParamInfo->CallBackType = ctImmediate;        pParamInfo->CallBackId   = GAIN_CBID;        pParamInfo->setEventClass(fdrGain);    }}```Now, with SDK 703003:```cpp// ModuleDefinition.h, included by MyModule.cpp only: it defines the MODULE_* constants#pragma once#include "../../sdk/UserDefinitions.h"constexpr AnsiCharPtr UserModuleBase::MODULE_NAME    = "my module";constexpr AnsiCharPtr UserModuleBase::MODULE_DESC    = "what my module does";constexpr AnsiCharPtr UserModuleBase::MODULE_VERSION = "1.0";constexpr NativeInt GAIN_FDR_CBID = 0x00100000;inline constexpr TParamInfo gainFdrInParamInfo {    .ParamType    = ptGainFader,    .Caption      = "gain",    .IsInput      = TRUE,    .IsOutput     = FALSE,    .CallBackType = ctImmediate,    .CallBackId   = GAIN_FDR_CBID};// MyModule.cpp#include "MyModule.h"#include "ModuleDefinition.h"void MyModule::onGetModuleInfo(TMasterInfo* pMasterInfo, TModuleInfo* pModuleInfo){    pModuleInfo->ModuleType = mtSimple;}void MyModule::onCreateParameters(TMasterInfo* pMasterInfo, TModuleInfo* pModuleInfo){    sdkCreateParam(gainFdrInParamInfo, gainFdrIn);}```- Write the `TParamInfo` fields in their declaration order. The others keep their default value:  `MaxValue` 1, `CallBackType` `ctNormal`, `CallBackId` -1, the rest 0, `FALSE` or `nullptr`.  A parameter without callback sets `.CallBackType = ctNone`.- The parameters appear in the order of the `sdkCreateParam` calls. `NumberOfParams` and  `onGetNumberOfParams` are no longer needed: keep the query results in `onAfterQuery`,  called before `onCreateParameters`.- When a parameter depends on the query (one audio input per channel), copy its `TParamInfo`,  change the copy (`Caption`...) and create it in a loop: see the AudioVolume example.- `onGetParamInfo` still works as the legacy system. Use one system or the other in a module.**5. Report errors with `sdkRaiseError`.** Register each message once in `ModuleDefinition.h`,then raise it where the problem happens. The user filters the messages with a verbosity level.```cpp// ModuleDefinition.hinline const int ERROR_INVALID_CHUNK = RegisterError(Level::Error, "invalid saved data, it was not restored");// MyModule.cppsdkRaiseError(ERROR_INVALID_CHUNK);```**6. Follow the naming of the examples.** A parameter is named `<name><Type><In|Out>`(`gainFdrIn`, `muteSwIn`, `resultFdrOut`), its `TParamInfo` adds `ParamInfo` (`gainFdrInParamInfo`)and its callback id is `<NAME>_<TYPE>_CBID` (`GAIN_FDR_CBID`).Also new in SDK 703003:  * `mtBackgroundJob`: the SDK adds the `processing` and `processing time` outputs of the job  * drag and drop of files on the panel: `onAcceptDragOver` and `onDragDrop`  * chunks: a float buffer written or read in one call (`sdkSetChunkFromFloatPointer`,    `sdkGetChunkToFloatPointer`), and the `UsineChunk` reader of `sdk/UsineChunks.h`  * `sdkGetBlockDuration()`; `TMasterInfo::BlocSize` is deprecated, use `sdkGetBlocSize()`A module built with SDK 703003 needs an up-to-date Usine Hollyhock 7. The modules built with anolder SDK keep working.To start a new module, copy the TemplateModule example or follow the[Getting Started](wiki/getting-started.md) of the wiki, and read the[Module Conventions](wiki/sdk/module-conventions.md).
Statistics: Posted by senso — 04 Nov 2026, 10:04
Thanx !
CODE:
