the "numsample" input is available as soon as you click on the arrow in the header of the module.
Yes. Of course. I am stupid. Thanks to remind me this. I am very impressed by the loading speed of Usine.exe v7. HH7 also seems to work much better with multichannel VST plugins (or multi instances of VST plugins that communicate internally ...) by either correctly assigning the VST plugin inputs and outputs or asking their exact numbers in some cases. I had many problems in the past with some versions of HH6 (notably after 6.0.250204) that did not manage well some VST plugins ...
I use a lot of VST plugins, and HH7 refuses to open my HH6 workspaces when a VST plugin is present.
Sorry I was wrong. HH7 does not refuse to open my HH6 workspaces, but it asks many times how many inputs and outputs are associated to the VST plugins I use because this information is not saved in the HH6 wkp. I thought it was a bug but it is simply the new behavior of HH7 with some VST plugins.
]]>2026-10-30T00:36:07+01:002026-10-30T00:36:07+01:00https://brainmodular.org/forums/viewtopic.php?t=7478&p=46470#p46470the "numsample" input is available as soon as you click on the arrow in the header of the module.
Cheers Olivar
Statistics: Posted by oli_lab — 30 Oct 2026, 00:36
]]>2026-10-29T20:22:46+01:002026-10-29T20:22:46+01:00https://brainmodular.org/forums/viewtopic.php?t=7478&p=46469#p46469Statistics: Posted by epiat — 29 Oct 2026, 20:22
2026-10-29T19:33:01+01:002026-10-29T19:33:01+01:00https://brainmodular.org/forums/viewtopic.php?t=7478&p=46468#p46468 I’m currently testing the beta version of HH7 and trying to reuse my HH6 workspaces in HH7. The process is quite time-consuming because I use a lot of VST plugins, and HH7 refuses to open my HH6 workspaces when a VST plugin is present. So I have to remove them from my old wkp files and reimport them into my new HH7 workspaces.
The problem I’m encountering involves the audio delay module, which I use very often with VST plugins.
In HH6, it is possible to feed the audio module with a “num samples” input (integer value), but this input is currently not available in HH7. This is quite inconvenient when I need to synchronize different audio paths—some of which go through a VST plugin that has its own sample-based latency (this latency is always provided in the VST plugin’s outputs), while others do not.
"Processing" time is the same for audio in 1 & 2 channels. Audio delay is just here to compensate the VST plugin latency because audio out 1 & 2 have to be in sync.
I am therefore requesting that the “num samples” input be added back in HH7 to the audio delay module to avoid having to perform a mathematical calculation (taking into account the sampling rate used by HH) to determine the audio delay value in ms with the latency value (samples) given by the VST module. If it is not possible, could you provide a new basic module to convert from samples to ms (taking into account the current sampling rate of the audio engine) ?
Cheers Olivar
]]>2026-10-29T19:33:01+01:002026-10-29T19:33:01+01:00https://brainmodular.org/forums/viewtopic.php?t=7478&p=46468#p46468 I’m currently testing the beta version of HH7 and trying to reuse my HH6 workspaces in HH7. The process is quite time-consuming because I use a lot of VST plugins, and HH7 refuses to open my HH6 workspaces when a VST plugin is present. So I have to remove them from my old wkp files and reimport them into my new HH7 workspaces.
