ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2026-10-25T11:03:10+01:00 https://brainmodular.org/forums/app.php/feed/topic/7477 2026-10-25T11:03:10+01:00 2026-10-25T11:03:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=7477&p=46464#p46464 <![CDATA[Re: Sampler behavior in the grid]]>
Works perfect! Thanks Marseille team!
I was born in Marseille !
Statistics: Posted by oli_lab — 25 Oct 2026, 11:03
2026-10-24T19:59:17+01:00 2026-10-24T19:59:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=7477&p=46463#p46463 <![CDATA[Re: Sampler behavior in the grid]]> Statistics: Posted by XpiR — 24 Oct 2026, 20:59
2026-10-24T15:44:16+01:00 2026-10-24T15:44:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=7477&p=46462#p46462 <![CDATA[Re: Sampler behavior in the grid]]>
I've found where the problem comes from. The play buttons need to be set to ‘if rack is on’ in the MIDI Learn menu.
*1 !
Statistics: Posted by oli_lab — 24 Oct 2026, 16:44
2026-10-24T07:07:53+01:00 2026-10-24T07:07:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=7477&p=46461#p46461 <![CDATA[Re: Sampler behavior in the grid]]> Capture d’écran 2026-10-24 080308.jpg
Statistics: Posted by rlgsbt — 24 Oct 2026, 08:07
2026-10-24T00:11:38+01:00 2026-10-24T00:11:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=7477&p=46460#p46460 <![CDATA[Re: Sampler behavior in the grid]]> It is made with HH7 20261014
GRID_test fixed2.wkp
Statistics: Posted by oli_lab — 24 Oct 2026, 01:11
2026-10-23T18:59:04+01:00 2026-10-23T18:59:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=7477&p=46459#p46459 <![CDATA[Re: Sampler behavior in the grid]]> Your wkp seems to be empty (?)
Statistics: Posted by XpiR — 23 Oct 2026, 19:59
2026-10-23T18:51:40+01:00 2026-10-23T18:51:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=7477&p=46458#p46458 <![CDATA[Re: Sampler behavior in the grid]]> I had a look at your .wkp, and noticed the play button misbehave : I made a quick fix by putting the play button in an always-on patch, and make use of busses.
I recommand to do like this (i.e. putting controls that are common to different patches) as it is easier to maintain
I used busses, but if you have many controls, you may use global arrays.
GRID_test fixed.wkp
Statistics: Posted by oli_lab — 23 Oct 2026, 19:51
2026-10-23T11:47:53+01:00 2026-10-23T11:47:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=7477&p=46457#p46457 <![CDATA[Re: Sampler behavior in the grid]]> Tu as raison, c'est très étrange. tu devrais le faire remonter à Support@brainmodular.com
Statistics: Posted by rlgsbt — 23 Oct 2026, 12:47
2026-10-23T08:54:01+01:00 2026-10-23T08:54:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=7477&p=46456#p46456 <![CDATA[Sampler behavior in the grid]]> Sampler B in the grid section 2.
Both have a play button controlled by the same button midi controller.
When I jump from grid section 1 -> 2, the sampler B plays once, it's like if the midi command had a residual persistence.
Check the attached wkp (here the midi command is replaced by "P" shortcut, which gives the same result)
Statistics: Posted by XpiR — 23 Oct 2026, 09:54
*1 !
GRID_test fixed.wkp
