2026-07-10T19:31:17+01:002026-07-10T19:31:17+01:00https://brainmodular.org/forums/viewtopic.php?t=7457&p=46355#p46355Statistics: Posted by rlgsbt — 10 Jul 2026, 20:31
]]>2026-07-10T19:27:31+01:002026-07-10T19:27:31+01:00https://brainmodular.org/forums/viewtopic.php?t=7457&p=46354#p46354Your video is sealed by your GPU. So you should have to much process globally and get some cracks. Try to reduce the video resolution. And if you have a video/GPU, take care to use it when you open Usine (not the motherboard)
]]>2026-07-10T18:34:20+01:002026-07-10T18:34:20+01:00https://brainmodular.org/forums/viewtopic.php?t=7457&p=46353#p46353Statistics: Posted by Gilsornette — 10 Jul 2026, 19:34
]]>2026-07-10T18:33:36+01:002026-07-10T18:33:36+01:00https://brainmodular.org/forums/viewtopic.php?t=7457&p=46352#p46352 I' using (or rather trying to use) video in a workspace . My video rack is containing only a video player, a translation patch and scale patch; I can see it's around 1% CPU. When I use it with some other racks, I got some audio crackling. The global CPU of Usine is around 45%, not more. Any idea of what might cause this? Thank you in advance
Statistics: Posted by Gilsornette — 10 Jul 2026, 19:33
]]>BrainModularBrainModular Users Forum2026-07-10T21:49:59+01:00https://brainmodular.org/forums/app.php/feed/topic/74572026-07-10T21:49:59+01:002026-07-10T21:49:59+01:00https://brainmodular.org/forums/viewtopic.php?t=7457&p=46356#p46356Statistics: Posted by Gilsornette — 10 Jul 2026, 22:49
]]>2026-07-10T19:31:17+01:002026-07-10T19:31:17+01:00https://brainmodular.org/forums/viewtopic.php?t=7457&p=46355#p46355Statistics: Posted by rlgsbt — 10 Jul 2026, 20:31
