ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2008-05-21T17:20:35+01:00https://brainmodular.org/forums/app.php/feed/topic/7442008-05-21T17:20:35+01:002008-05-21T17:20:35+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=4410#p4410Statistics: Posted by cmodica — 21 May 2008, 18:20
2008-05-21T12:35:58+01:002008-05-21T12:35:58+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=4406#p4406Actually your pb is hard (almost impossible) to solve except to have 50 samplers in your patch...(
You can explore a way to manage the file number in a sub-patch and with a counter which will ignore unwanted files?
]]>2008-05-20T15:58:36+01:002008-05-20T15:58:36+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=4402#p4402I know you work hard and alone and you make a real good job. The 3.64 is very great.
I need to build something like that :
When there is 50 files in the sampler, delete the old one when record a new one. And so when there is always 50 files in the sampler list from now.
Did you have an idea to help me ?
Statistics: Posted by cmodica — 20 May 2008, 16:58
]]>2008-02-19T10:08:06+01:002008-02-19T10:08:06+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3840#p3840Statistics: Posted by cmodica — 19 Feb 2008, 10:08
]]>2008-02-18T17:23:57+01:002008-02-18T17:23:57+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3839#p3839
Just an idea..: Wouldn't it be simpler to have a parameter in the sample list to use a directory, possibly with an option to choose sorting between date/time and filename?
Yes Bsork as usual you're right. And more generally, try to find a way to manage filenames, directories,etc, inside usine with the text flows.
]]>2008-02-18T13:36:01+01:002008-02-18T13:36:01+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3838#p3838 Thank you very much, you are the best ....
Statistics: Posted by cmodica — 18 Feb 2008, 13:36
]]>2008-02-18T13:34:20+01:002008-02-18T13:34:20+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3837#p3837 That way one sampler could do the recording and create new files, while another plays through the directory listing. Deletion of old files could be accomplished by a simple CMD file called once in a while.
]]>2008-02-18T11:18:25+01:002008-02-18T11:18:25+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3836#p3836You probably need several samplers and a complex script.
The only way is to create a new param in the sample, something like 'do not affect the list when rec'. Will be implemented in the next version.
]]>2008-02-18T09:20:43+01:002008-02-18T09:20:43+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3835#p3835The first one is always the same. Each time i rec, the sampler return on the begining of the sample.
The second is that i'am going to put this system in a place and it will rec short peaces of the landscape, according different parameters that i decided. And i want peaple earing the last 4 hours in the same time they earing the "natural landscape" like every day .... So 4 hours of peaces of sound perahp's will be 1 mn of sound but perhap's it will be 15 mn of sound ....
It is a litle bit more complex but it is the general process that i'm talking about on this forum.
Thank you very much for your help.
Statistics: Posted by cmodica — 18 Feb 2008, 09:20
]]>2008-02-18T09:04:39+01:002008-02-18T09:04:39+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3834#p3834 - mode = single sample - rec & play = ON - rec mode = append
]]>2008-02-17T20:32:06+01:002008-02-17T20:32:06+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3833#p3833 For 1 - I just want to add a new recording file to the sampler list
For 2 - I think like you, i need to build a patch. But if i "build a patch with a counter that increment the total number of sample after each recording, and resets it (start from the beginning) after REC OFF" I don't think it produce what i want ... Because, for example, if sampler reading file 45, if there is 100 files, and if i recording a new file, i want the sampler reading file 45, and 50, 51 .... until the end, so now 101 and after loop to the begining, etc ....
The best, would be a sampler that read a list of sample in next mode and add each new rec at the end of the list without stopping the reading. It read always sample 1, sample 2, ....... until the end. Never stop, never go back or forward, always one after the other. And the list of sample it never the same. At the begening there is 1 sample, 10 mns later there is 8 samples, 30 mns later there is 60 samples ..... But if when it recording the sample 60, the sampler reading the sample 7, never mind, it reading the 7, 8, 9 .... and perhaps the Sample 60 will be read 10mns after it was recording.
If you want i can send by mail, or put somewhere the patch that i begin to build ?
Statistics: Posted by cmodica — 17 Feb 2008, 20:32
]]>2008-02-17T19:43:17+01:002008-02-17T19:43:17+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3832#p3832 for the point 2) you have to build a patch with a counter that increment the total number of sample after each recording, and resets it (start from the beginning) after REC OFF.
Since it's a particular behaviour I can't make it as an Usine built-in. But construct a patch is probably not so difficult?
]]>2008-02-17T10:59:21+01:002008-02-17T10:59:21+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3831#p3831 But i always have a problem with the Rec & Play and Play mod Next in loop ... ???? !!!!
If the sampler is in mode : Next location : file sync mode : loop
And "Rec & Play" is ON
it is impossible to save the last recorded (exepted for the first one, of course). When record stop it "save rand" to add the new rec at the sampler list, but the following message appears : Nothing recorded, can't save.
If "Rec & Play" is OFF
it works fine but the reading stop when it recording ....
I am going to explain what i'd like to make. I want to record the input sound. When the record is end i "save rand" this file. And a few second later i want to record an other sound and the sampler reading the first one. I save rand this new sound at the end of recording. Now i want the sampler read the first sound, and the second one in loop mode.
A few second later i want to record an other sound and the sampler reading the first and the second one in loop mode and don't care abount this new recording. When recording is end it "save rand" and now the sampler read the three sound in next mode and loop ......
So, a few minutes after i have 100 sound in the sampler list. I want the sampler read all this sample in order, never stop and add the new sample recorded in the end of the list without stopping the read ....
I hope it is clear ??? :/
Statistics: Posted by cmodica — 17 Feb 2008, 10:59
]]>2008-02-12T10:20:39+01:002008-02-12T10:20:39+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3789#p3789 For my second problem, it is the same if "Rec & Play" is ON or OFF ....
Statistics: Posted by cmodica — 12 Feb 2008, 10:20
]]>2008-02-11T22:45:57+01:002008-02-11T22:45:57+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3786#p3786I'll post an update tomorrow. If you can't wait, the samplerx1 (1 channel) works fine.
]]>2008-02-11T20:39:16+01:002008-02-11T20:39:16+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3785#p3785for the point 1) you are right, there is a problem in loop mode: the order isn't correct. I'll check it.
]]>2008-02-11T14:59:02+01:002008-02-11T14:59:02+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=3783#p3783 1 - The sampler read only the sample 1-3-5-7 .... and never the 0-2-4-6-8 ... But it is strange beacause if there is only three samples it reads 1 and after it reads 0 and it never read 2 ????? :/
2 - If i record a new sample on the fly, during the sample playing the list in next mode and sync loop (with the "REC & Play" ON), the reading go to the begenning of the list. And i'd like it playing the list in order, never stop and add my new sample in the end of the list ..... :/
Someone have an idea ?
I hope it is clear ....
Statistics: Posted by cmodica — 11 Feb 2008, 14:59
]]>BrainModularBrainModular Users Forum2008-05-21T17:20:35+01:00https://brainmodular.org/forums/app.php/feed/topic/7442008-05-21T17:20:35+01:002008-05-21T17:20:35+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=4410#p4410Statistics: Posted by cmodica — 21 May 2008, 18:20
]]>2008-05-21T12:35:58+01:002008-05-21T12:35:58+01:00https://brainmodular.org/forums/viewtopic.php?t=744&p=4406#p4406Actually your pb is hard (almost impossible) to solve except to have 50 samplers in your patch...(
