ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2025-10-02T11:36:01+01:00 https://brainmodular.org/forums/app.php/feed/topic/7397 2025-10-02T11:36:01+01:00 2025-10-02T11:36:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=7397&p=46054#p46054 <![CDATA[Re: Missing midi device from devices view]]>
another prob im facing (but it's windows related) is usine hangs on close sometimes, i finally understood it was because it's trying to delete files in my usine folder on desktop that for some reasons keep on reverting back to "read only" even tho i right clicked and unticked read only
i will dig on how to fix that those days, but if anyone knows, im taking!
Statistics: Posted by 23fx23 — 02 Oct 2025, 12:36
2025-10-02T11:35:40+01:00 2025-10-02T11:35:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=7397&p=46053#p46053 <![CDATA[Re: Missing midi device from devices view]]>
Statistics: Posted by 23fx23 — 02 Oct 2025, 12:35
2025-10-01T23:08:38+01:00 2025-10-01T23:08:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=7397&p=46051#p46051 <![CDATA[Re: Missing midi device from devices view]]> I think that you can set the name of the USB midi differently from one arduino to the other so the USB enumerator won't get confused :
https://github.com/adafruit/Adafruit_Ti ... _ports.ino
In you case use only 1 port
hope this helps
Statistics: Posted by oli_lab — 02 Oct 2025, 00:08
2025-10-01T19:21:36+01:00 2025-10-01T19:21:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=7397&p=46049#p46049 <![CDATA[Re: Missing midi device from devices view]]> but in case it happens to someone else: i managed to get it back deleting all usine .ini files in config
Statistics: Posted by 23fx23 — 01 Oct 2025, 20:21
2025-10-01T19:12:26+01:00 2025-10-01T19:12:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=7397&p=46048#p46048 <![CDATA[Missing midi device from devices view]]> I play around a lot with arduino /esp32 as midi devices those days.
everything worked fine so far , but today for some reason there is one device i can't see in device view, so i can't drop it on racks.
i do see it in setup however. Ive tried rescan/recreate, delete all files in configg default device,
but i can't seem to manage to get it back,
any idea? (i do see it on other daws or midiview, so for debug it should be ok i think)
Statistics: Posted by 23fx23 — 01 Oct 2025, 20:12
hope this helps
