ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2025-04-25T07:59:50+01:00 https://brainmodular.org/forums/app.php/feed/topic/7332 2025-04-25T07:59:50+01:00 2025-04-25T07:59:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=7332&p=45805#p45805 <![CDATA[Re: Wishing list]]>
Statistics: Posted by cmodica — 25 Apr 2025, 08:59
2025-04-25T07:10:12+01:00 2025-04-25T07:10:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=7332&p=45804#p45804 <![CDATA[Re: Wishing list]]> Statistics: Posted by Gilsornette — 25 Apr 2025, 08:10
2025-04-24T16:32:22+01:00 2025-04-24T16:32:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=7332&p=45803#p45803 <![CDATA[Re: Wishing list]]> Statistics: Posted by rlgsbt — 24 Apr 2025, 17:32
2025-04-24T10:59:30+01:00 2025-04-24T10:59:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=7332&p=45801#p45801 <![CDATA[Re: Wishing list]]>
- possibility to move the devices in the devices menu ; to sort them as needed, and also because Usine chooses by default the 1st device as output
OK
- being able to move a section in the grid by «affecting» the new location, rather than by sliding (complicated when long grid)
OK
- in patch settings , having a «reduce patch» input; there are two minimize inouts but no reduce ("-" in header)
OK
- being able to open several patches windows simultaneously (convenient for comparing, searching ...) > probably very complicated but we never know...
not sure...
- in audio samplers modules, a trigger when it comes to end, not only on restart; sometimes more useful than when restart > to change zone markers for example (when you have to trigger somthing before the loop recovery)
The "is playing" output does a good job ?
- already asked , but (for me) indispensable : the possibility to save presets lists
not sure it's possible...
- an option to make the intensity of the LEDs proportional to the signal received
A new "audio-vu-meter-led" module will be created
- mixer: an option to have only active racks visibles
OK
- it'd be very useful if the "record on click" option also works with midi/osc remotes
hard implementation because it is not easy to know when a MIDI flow has stopped... unless wait few seconds
- having an output on objects to be able to display names of drag and drop binds and not only buses
OK
Statistics: Posted by senso — 24 Apr 2025, 11:59
2025-04-18T08:14:23+01:00 2025-04-18T08:14:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=7332&p=45786#p45786 <![CDATA[Re: Wishing list]]> Thank you.
Statistics: Posted by cmodica — 18 Apr 2025, 09:14
2025-04-17T15:51:38+01:00 2025-04-17T15:51:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=7332&p=45785#p45785 <![CDATA[Re: Wishing list]]> I'll study them carefully.
Statistics: Posted by senso — 17 Apr 2025, 16:51
2025-02-15T16:39:22+01:00 2025-02-15T16:39:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=7332&p=45705#p45705 <![CDATA[Wishing list]]>
I regularly take notes of things that I would like to see modified or implemented in Usine. Here's my wishing list:-)
Please don't hesitate to tell me if ot's not a good idea to post so much demands in one topic...
- devices menu displays the device group name
- being able to drag and drop a switch into the grid and have access to on and off values (as fader in non-curve mode)
- an option to load samples in midi sampler in loop mode by default
- a global option «ignore show rack/patch when active on grid»; sometimes useful to be able to observe a rack/patch by "scrolling" the grid without having the other ones shown
Thank you very much
Statistics: Posted by Gilsornette — 15 Feb 2025, 16:39
OK
OK
OK
not sure...
OK
OK
Thank you very much
