ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2025-01-11T09:55:11+01:00 https://brainmodular.org/forums/app.php/feed/topic/7311 2025-01-11T09:55:11+01:00 2025-01-11T09:55:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45656#p45656 <![CDATA[Re: Nektar Pacer + Usine]]>
And it fits in my backpack... well, without the computer, without the sound card, without the other controllers. 🤣
Statistics: Posted by SylvainT — 11 Jan 2025, 09:55
2025-01-10T12:22:18+01:00 2025-01-10T12:22:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45654#p45654 <![CDATA[Re: Nektar Pacer + Usine]]> Statistics: Posted by 23fx23 — 10 Jan 2025, 12:22
2024-12-30T19:04:07+01:00 2024-12-30T19:04:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45648#p45648 <![CDATA[Re: Nektar Pacer + Usine]]>
Statistics: Posted by oli_lab — 30 Dec 2024, 19:04
2024-12-29T11:22:23+01:00 2024-12-29T11:22:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45647#p45647 <![CDATA[Re: Nektar Pacer + Usine]]> https://www.audiofront.net/MIDIExpression.php and piano pedals
it looks like the line 6 one ...
Statistics: Posted by grego mondo — 29 Dec 2024, 11:22
2024-12-27T09:29:50+01:00 2024-12-27T09:29:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45644#p45644 <![CDATA[Re: Nektar Pacer + Usine]]>
https://www.thomann.de/fr/line6_fbv_express_usb.htm. very good with an expression pedal and USB powered
for small interaction I use https://fr.audiofanzine.com/pedalier-co ... gidy/umi3/ also USB powered
Statistics: Posted by senso — 27 Dec 2024, 09:29
2024-12-18T17:19:31+01:00 2024-12-18T17:19:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45626#p45626 <![CDATA[Re: Nektar Pacer + Usine]]>
For smaller usb stuff, there's https://iconproaudio.com/product/g-board/
not so easy to find
Hi, I saw this one or more exactly, I heard it : the switches make a awful lot of clicky noise !
good for heavy metal I suppose.
Yes it makes noise (I forgot that !) but that's the smaller I know !
If size matters ...
Statistics: Posted by grego mondo — 18 Dec 2024, 17:19
2024-12-18T16:56:38+01:00 2024-12-18T16:56:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45625#p45625 <![CDATA[Re: Nektar Pacer + Usine]]>
not so easy to find
Statistics: Posted by oli_lab — 18 Dec 2024, 16:56
2024-12-18T09:18:00+01:00 2024-12-18T09:18:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45624#p45624 <![CDATA[Re: Nektar Pacer + Usine]]> https://iconproaudio.com/product/g-board/
not so easy to find
Statistics: Posted by grego mondo — 18 Dec 2024, 09:18
2024-12-17T14:27:21+01:00 2024-12-17T14:27:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45623#p45623 <![CDATA[Re: Nektar Pacer + Usine]]> The FCB1010 is too big, heavy and has no USB connection.
I may try the PACER, and send some feedback.
D
Statistics: Posted by daviche — 17 Dec 2024, 14:27
2024-12-09T22:43:15+01:00 2024-12-09T22:43:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45609#p45609 <![CDATA[Re: Nektar Pacer + Usine]]> I checked the specs of the Nectar Pacer : if it's to use it with Usine only, it is overkill !
maybe you'd be better off with a midi only pedal board as the Behringer FCB1010
the expression pedals will do wonders with Usine as well !
cheers.
Statistics: Posted by oli_lab — 09 Dec 2024, 22:43
2024-12-06T15:38:06+01:00 2024-12-06T15:38:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=7311&p=45597#p45597 <![CDATA[Nektar Pacer + Usine]]>
does anyone uses the Nectar Pacer to control Usine ?
Anything to say about this controller ?
David
Statistics: Posted by daviche — 06 Dec 2024, 15:38
not so easy to find
If size matters ...
not so easy to find
not so easy to find
D
cheers.
David
