ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2024-09-21T16:16:08+01:00 https://brainmodular.org/forums/app.php/feed/topic/7289 2024-09-21T16:16:08+01:00 2024-09-21T16:16:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=7289&p=45522#p45522 <![CDATA[Re: Share patches]]>
Thanks to both of you. I know Global Arrays and I'm already using them in my workspaces. Very useful indeed.
I will think about that again but I'm afraid that , in this particular case, it'd be way too long and comlpicated:-(
Have a nice week end!
Statistics: Posted by Gilsornette — 21 Sep 2024, 17:16
2024-09-20T18:48:42+01:00 2024-09-20T18:48:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=7289&p=45521#p45521 <![CDATA[Re: Share patches]]>
Yes, mulitmonitor apps are a good alternative, but can be tricky when there's a lot to do.
Using Global Arrays is a really good solution, easy to implement (once you have made one or two to get the idea), strong and efficient.
It can be a huge work if you want to duplicate all your wkp. But, if correctly made, you only need to build one workspace.
Best
Statistics: Posted by SylvainT — 20 Sep 2024, 19:48
2024-09-20T09:55:32+01:00 2024-09-20T09:55:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=7289&p=45520#p45520 <![CDATA[Re: Share patches]]> I know it could be a lillte bit fastidious
Statistics: Posted by joffo78 — 20 Sep 2024, 10:55
2024-09-20T09:14:49+01:00 2024-09-20T09:14:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=7289&p=45519#p45519 <![CDATA[Re: Share patches]]> audience when my setup is on stage , and check things. For now I use a multi monitor app (space desk) and duplicate my screen to an android tablet but , with heavy workspaces, it sometimes lags or works badly.
Statistics: Posted by Gilsornette — 20 Sep 2024, 10:14
2024-09-20T08:56:09+01:00 2024-09-20T08:56:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=7289&p=45518#p45518 <![CDATA[Re: Share patches]]> I'm afraid this function is discountinued.
Maybe the team should delete this video ...
nevertheless it exist a multiple alternatives.
As making global array and share it on the network
Statistics: Posted by joffo78 — 20 Sep 2024, 09:56
2024-09-19T10:50:57+01:00 2024-09-19T10:50:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=7289&p=45517#p45517 <![CDATA[Share patches]]>
Is it still possible with HH6 to share patches over the lan? As in this video https://www.youtube.com/watch?v=umwe0JmBixA
Thank you
Statistics: Posted by Gilsornette — 19 Sep 2024, 11:50
Best
Thank you
