ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2024-05-30T09:33:21+01:00https://brainmodular.org/forums/app.php/feed/topic/72562024-05-30T09:33:21+01:002024-05-30T09:33:21+01:00https://brainmodular.org/forums/viewtopic.php?t=7256&p=45384#p45384https://www.amazon.fr/gp/product/B0CCXN ... =UTF8&th=1 the pro version around 800€
]]>2024-05-21T18:08:32+01:002024-05-21T18:08:32+01:00https://brainmodular.org/forums/viewtopic.php?t=7256&p=45378#p45378 I do not see the exact model listed here, but when I search this page for "16x" some similar models come up that seem to perform favorably https://www.notebookcheck.net/DPC-Laten ... 376.0.html
Between ensuring that your laptop has adequate resources available for good realtime performance and a rock solid audio interface (RME?), as long as you are certain that you have enough system memory, then you should be good to go
Statistics: Posted by gurulogic — 21 May 2024, 19:08
]]>2024-05-14T18:14:27+01:002024-05-14T18:14:27+01:00https://brainmodular.org/forums/viewtopic.php?t=7256&p=45370#p45370I opted for a MINIS FORUM Venus UM790 Pro Mini PC AMD Ryzen 9 7940HS with 32Go RAM it's not a laptop but even smaller ! added a small keyboard + a 7" beetronic tactile screen !
run very well !
Statistics: Posted by oli_lab — 14 May 2024, 19:14
]]>2024-05-14T15:11:38+01:002024-05-14T15:11:38+01:00https://brainmodular.org/forums/viewtopic.php?t=7256&p=45369#p45369Statistics: Posted by rlgsbt — 14 May 2024, 16:11
2024-05-14T13:59:35+01:002024-05-14T13:59:35+01:00https://brainmodular.org/forums/viewtopic.php?t=7256&p=45368#p45368Having worked on a Mac for many years (including with Usine), I'm thinking of buying a PC laptop to use exclusively on stage, with Usine. Can you give me your opinion on a configuration like this?
Asus VivoBook 16X N3604YA-MB014W (16", IPS, Full HD+, 16:10, 60 Hz, Ryzen 7 7730U, RAM 16 Go DDR 4, SSD 1 To, Windows 11) AMD Ryzen 7 7730U (Octo Core 2 GHz / 4.5 GHz Turbo - 16 Threads - Cache 16 Mo) CPU frequency 3.2 Ghz, 8 core AMD Radeon Graphics
Thanks !
Statistics: Posted by daviche — 14 May 2024, 14:59
]]>BrainModularBrainModular Users Forum2024-05-30T09:33:21+01:00https://brainmodular.org/forums/app.php/feed/topic/72562024-05-30T09:33:21+01:002024-05-30T09:33:21+01:00https://brainmodular.org/forums/viewtopic.php?t=7256&p=45384#p45384https://www.amazon.fr/gp/product/B0CCXN ... =UTF8&th=1 the pro version around 800€
run very well !
]]>2024-05-14T13:59:35+01:002024-05-14T13:59:35+01:00https://brainmodular.org/forums/viewtopic.php?t=7256&p=45368#p45368Having worked on a Mac for many years (including with Usine), I'm thinking of buying a PC laptop to use exclusively on stage, with Usine. Can you give me your opinion on a configuration like this?
Thanks !
