2024-04-09T16:57:12+01:002024-04-09T16:57:12+01:00https://brainmodular.org/forums/viewtopic.php?t=7249&p=45337#p45337please send bug report by mail : support@brainmodular.com
]]>2024-04-05T09:48:15+01:002024-04-05T09:48:15+01:00https://brainmodular.org/forums/viewtopic.php?t=7249&p=45336#p45336 This unexpected crash happens also on Windows 11, but it takes a lot more time before the error message shows up.
I tried running an Intel release version of Usine 6 on my M1 Mac (through Rosetta), and the crash also happens, but with an additional audio drop error pointing to the patch's corresponding rack.
Statistics: Posted by VictorWetzel — 05 Apr 2024, 10:48
]]>2024-04-05T09:36:29+01:002024-04-05T09:36:29+01:00https://brainmodular.org/forums/viewtopic.php?t=7249&p=45335#p45335 And I can also provide an error code :
[46] Error : E901 patch process : Set Value module : audio_pan_surround_panner inlet : X 1 rack : 1 patch : MinimumCrashingExample-SurroundAudioPanner-2024-04-05-UsineHH6.0.240403
I tried upgrading my Usine version. I also tried coding the same patch in the last Usine 5 version available, and it exhibited the same behaviour.
Now, the patch runs fine for 20 or 30 secondes, then the above error code shows up. After a few more seconds, Usine crashes.
This behaviour didn't exist for older Usine 5 versions (something like versions that released in late 2022, november, december).
Statistics: Posted by VictorWetzel — 05 Apr 2024, 10:36
]]>2024-03-28T23:14:24+01:002024-03-28T23:14:24+01:00https://brainmodular.org/forums/viewtopic.php?t=7249&p=45334#p45334 First post here !
I have a simple patch, called "cyclic-panner" : basically a surround panner with some LFO. I created this patch with Usine 5. It worked fine with beta versions of Usine 6.
Since I upgraded Usine to Usine 6 and that I upgraded my Mac, it invariably crashes Usine to use this patch. Can't see error messages.
Can someone run it on his/her machine ? It might be a weird bug, a problem in my patch, a machine dependent problem... I don't know !
Thank you !
PS : crash experienced with Usine-M-Series-6.0.231116 (beta) and Usine-MacOS-M-Series-6.0.240322
Statistics: Posted by VictorWetzel — 28 Mar 2024, 23:14
]]>BrainModularBrainModular Users Forum2024-04-10T11:56:19+01:00https://brainmodular.org/forums/app.php/feed/topic/72492024-04-10T11:56:19+01:002024-04-10T11:56:19+01:00https://brainmodular.org/forums/viewtopic.php?t=7249&p=45339#p45339Statistics: Posted by VictorWetzel — 10 Apr 2024, 12:56
]]>2024-04-09T16:57:12+01:002024-04-09T16:57:12+01:00https://brainmodular.org/forums/viewtopic.php?t=7249&p=45337#p45337please send bug report by mail : support@brainmodular.com
Thank you !
