ok oliver. On some software it's possible to ctrl-click to have more precision on fader. It could be an alternative ? If not, I will build one. Thanks you for your answer.
]]>2008-01-24T22:03:58+01:002008-01-24T22:03:58+01:00https://brainmodular.org/forums/viewtopic.php?t=724&p=3677#p3677Statistics: Posted by senso — 24 Jan 2008, 22:03
2008-01-24T21:36:50+01:002008-01-24T21:36:50+01:00https://brainmodular.org/forums/viewtopic.php?t=724&p=3676#p3676Statistics: Posted by bsork — 24 Jan 2008, 21:36
]]>2008-01-24T21:16:10+01:002008-01-24T21:16:10+01:00https://brainmodular.org/forums/viewtopic.php?t=724&p=3674#p3674Thanks you for your answer.
Statistics: Posted by moody33 — 24 Jan 2008, 21:16
]]>2008-01-24T20:46:17+01:002008-01-24T20:46:17+01:00https://brainmodular.org/forums/viewtopic.php?t=724&p=3673#p3673But I suggest you to create a patch with an interface builder window and a huge fader connected to the tempo of a synchro module! Put it as an insert of the master section. Will do the job perfectly?
]]>2008-01-24T21:36:50+01:002008-01-24T21:36:50+01:00https://brainmodular.org/forums/viewtopic.php?t=724&p=3676#p3676Statistics: Posted by bsork — 24 Jan 2008, 21:36
