ArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2024-01-11T14:09:06+01:00 https://brainmodular.org/forums/app.php/feed/topic/7200 2024-01-11T14:09:06+01:00 2024-01-11T14:09:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=7200&p=45183#p45183 <![CDATA[Re: Subpatch from selection]]>
Also Usine Objects are in scripts and soon will be in the SDK.
yeah tested a bit in script and opened the sdk ex, pretty cool suff! need to be organized still hehe but opens a lot of doors
Statistics: Posted by 23fx23 — 11 Jan 2024, 14:09
2024-01-10T21:42:16+01:00 2024-01-10T21:42:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=7200&p=45182#p45182 <![CDATA[Re: Subpatch from selection]]> Also Usine Objects are in scripts and soon will be in the SDK. Some ideas to help the spaghetti tangle of wires.
I would like all Usine modules to support my ParamMux system really :-)
Statistics: Posted by sm_jamieson — 10 Jan 2024, 21:42
2023-12-16T17:02:20+01:00 2023-12-16T17:02:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=7200&p=45135#p45135 <![CDATA[Re: Subpatch from selection]]> :P
Statistics: Posted by senso — 16 Dec 2023, 17:02
2023-12-12T03:25:30+01:00 2023-12-12T03:25:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=7200&p=45111#p45111 <![CDATA[Re: Subpatch from selection]]>
Statistics: Posted by SylvainT — 12 Dec 2023, 03:25
2023-12-11T19:21:40+01:00 2023-12-11T19:21:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=7200&p=45109#p45109 <![CDATA[Re: Subpatch from selection]]> for ex here if i cut the led in center, i will have to untangle/ keep track of eveyting that was connected to it if i copy/paste
but yeah, i should organize myself a bit more, and earlier in time :v
Statistics: Posted by 23fx23 — 11 Dec 2023, 19:21
2023-12-11T18:49:36+01:00 2023-12-11T18:49:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=7200&p=45106#p45106 <![CDATA[Re: Subpatch from selection]]> Statistics: Posted by senso — 11 Dec 2023, 18:49
2023-12-03T19:55:40+01:00 2023-12-03T19:55:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=7200&p=45097#p45097 <![CDATA[Re: Subpatch from selection]]> of course, you have to manage the IO (and polyphony) and clear the parent pannel, but it's quite easy
Statistics: Posted by rlgsbt — 03 Dec 2023, 19:55
2023-12-03T13:46:57+01:00 2023-12-03T13:46:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=7200&p=45096#p45096 <![CDATA[Subpatch from selection]]>
Im used to something in houdini which can do this "group to supacth" thing and find it very conveniant to keep stuff cleaner and organized.
( houdini is def not same team size and price tag^^ i reckon)
basically select a bunch of items in patcher , -> to subpatch.
seems quite complex as ideally would need to anayse every implied wires , create every datas IO and rewire in/out of new subpasth,
im prob dreaming here lol, just an idea..
Statistics: Posted by 23fx23 — 03 Dec 2023, 13:46
