ArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2023-01-13T11:29:14+01:00 https://brainmodular.org/forums/app.php/feed/topic/7100 2023-01-13T11:29:14+01:00 2023-01-13T11:29:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=7100&p=44665#p44665 <![CDATA[Re: Converting CC value to DMX values]]> You have to make the conversion with usine and send dmx flow directly on a dmx interface.
Statistics: Posted by joffo78 — 13 Jan 2023, 11:29
2023-01-07T20:15:11+01:00 2023-01-07T20:15:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=7100&p=44651#p44651 <![CDATA[Re: Converting CC value to DMX values]]> Comes with a cost for sure.
There's a usb to dmx thingo from dmx King that is a cheaper alternative.
Statistics: Posted by oli_lab — 07 Jan 2023, 20:15
2023-01-07T14:15:07+01:00 2023-01-07T14:15:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=7100&p=44648#p44648 <![CDATA[Re: Converting CC value to DMX values]]>
Can you give me advice for a midi to DMX box ?
Thanks again
Statistics: Posted by noise2sine — 07 Jan 2023, 14:15
2023-01-04T23:05:27+01:00 2023-01-04T23:05:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=7100&p=44636#p44636 <![CDATA[Re: Converting CC value to DMX values]]> You'll need a dmx interface
Check dmx king
Statistics: Posted by oli_lab — 04 Jan 2023, 23:05
2023-01-04T16:24:16+01:00 2023-01-04T16:24:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=7100&p=44629#p44629 <![CDATA[Re: Converting CC value to DMX values]]> If you want to strictly convert all CC input in dmx you can use the following script ( see example)
// MIDI CC to ARRAY
// Paramters declaration
var input : Tparameter;
var output: Tparameter;
var reset : Tparameter;
// initialisation procedure
procedure init;
begin
input := CreateParam('midi in',ptMIDI,pioInput);
output := CreateParam('array out',ptArray,pioOutput);
output.Min(0);
output.Max(1);
output.Length(128);
reset := CreateParam('reset',ptButton,pioInput);
ModuleColor($FF3298DB);
end;
// Global Variables
var MIDI : TMIDI;
// Main Loop procedure
Procedure Process;
var i: integer;
begin
output.Length(128);
if reset.equal1
then begin
for i:=0 to 127
do output.asArray(i,0);
reset.asFloat(0);
end;
for i := 0 to getLength(input)-1
do begin
MIDI := input.asMidi(i);
if (MIDI.msg=176)
then begin
output.asArray(MIDI.data1,MIDI.data2/127);
end
else
if (MIDI.msg=128)
then begin
output.asArray(MIDI.data1,0);
end;
end;
end;
Statistics: Posted by joffo78 — 04 Jan 2023, 16:24
2023-01-04T13:55:11+01:00 2023-01-04T13:55:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=7100&p=44628#p44628 <![CDATA[Re: Converting CC value to DMX values]]>
Thank you !
Statistics: Posted by noise2sine — 04 Jan 2023, 13:55
2023-01-04T13:16:02+01:00 2023-01-04T13:16:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=7100&p=44627#p44627 <![CDATA[Re: Converting CC value to DMX values]]> In Usine DMX is a value in the range [0..1] and CC is a value in the range [0..127]. So a simple change scale does the trick?
see
demo CC 2 Dimmer.wkp
Statistics: Posted by senso — 04 Jan 2023, 13:16
2023-01-04T10:55:20+01:00 2023-01-04T10:55:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=7100&p=44626#p44626 <![CDATA[Converting CC value to DMX values]]>
Is it possible in Usine to convert from a CC value module data into DMX values ? I have a patch which send CC values but i need that this patch can send CC values converted to DMX ?
Help !!!!
Thank you !
Statistics: Posted by noise2sine — 04 Jan 2023, 10:55
Thanks again
Check dmx king
// MIDI CC to ARRAY
procedure init;
begin
output.Min(0);
output.Max(1);
output.Length(128);
end;
// Global Variables
var MIDI : TMIDI;
Procedure Process;
var i: integer;
begin
output.Length(128);
if reset.equal1
then begin
for i:=0 to 127
reset.asFloat(0);
end;
do begin
if (MIDI.msg=176)
then begin
end
else
if (MIDI.msg=128)
then begin
end;
end;
end;
Thank you !
see
Help !!!!
Thank you !
