ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2023-03-03T18:45:05+01:00https://brainmodular.org/forums/app.php/feed/topic/70552023-03-03T18:45:05+01:002023-03-03T18:45:05+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44728#p44728 please update the oli_lab_pack addon !
Statistics: Posted by oli_lab — 03 Mar 2023, 18:45
]]>2022-12-06T00:12:02+01:002022-12-06T00:12:02+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44543#p44543just need to update the oli_labàpack add on.
Statistics: Posted by oli_lab — 06 Dec 2022, 00:12
]]>2022-11-14T12:33:23+01:002022-11-14T12:33:23+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44461#p44461You are a master! Thank you so much. This pack is a fantastic resource for HH.
Statistics: Posted by cmodica — 14 Nov 2022, 12:33
]]>2022-11-09T23:13:25+01:002022-11-09T23:13:25+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44457#p44457the BWFdata module is in the oli_lab_pack module You need to remove the old one before downloading it there's a demo in the examples folder.
Statistics: Posted by oli_lab — 09 Nov 2022, 23:13
]]>2022-11-07T15:57:01+01:002022-11-07T15:57:01+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44448#p44448it will be wave only then I managed to get the name of the markers, if any. the Bext chunk is not very useful, I'll skip it for now. MAC Os version will be ready as soon as I managed to update the Mac Mini
Statistics: Posted by oli_lab — 07 Nov 2022, 15:57
]]>2022-11-07T13:04:29+01:002022-11-07T13:04:29+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44446#p44446thank you, very much.
Statistics: Posted by cmodica — 07 Nov 2022, 13:04
]]>2022-11-07T11:44:10+01:002022-11-07T11:44:10+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44445#p44445sorry for that, I'll fire up the Mac mini asap
Do you use Wav or Aiff ? so far the module only works for Wav with BWF data in it it is differently organised chunkwise form wav to aiff and I need to make a different logarithm.
Statistics: Posted by oli_lab — 07 Nov 2022, 11:44
]]>2022-11-07T10:47:01+01:002022-11-07T10:47:01+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44444#p44444 But i can't test your patch because i am on Mac OSX. The file "Oli_Lab_BWFdata.usr-OSX64" is not in the zip package.
Statistics: Posted by cmodica — 07 Nov 2022, 10:47
]]>2022-11-09T22:27:41+01:00 2022-11-05T22:43:56+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44443#p44443It was raining so, I did some coding :
will be in the addon soon
not finished yet but here for you to test it.
only the markers array output is working
I'm planning to get the name of the markers, that could be handy to select markers by name
the metada output would be to read comments from the BEXT chunk (comments, originator, loudness, etc... Maybe too much work but could be interesting
tell me !
cheers Olivar
Statistics: Posted by oli_lab — 05 Nov 2022, 22:43
]]>2022-11-04T12:30:30+01:002022-11-04T12:30:30+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44441#p44441I had a look in the SDK and nothing can read the BWF data so far. I made a BWF file with reaper and trying to localize the chunk. so far I managed to pin point the list of markers at the end, as well as their position in samples. Need to get some other datas as the total number of samples and I should be up and running. Mind you it's a side project, so be patient !
Statistics: Posted by oli_lab — 04 Nov 2022, 12:30
]]>2022-11-04T10:14:21+01:002022-11-04T10:14:21+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44439#p44439I will send you a bwf file as soon as i will come back to my studio, next week. Thank you very much.
Statistics: Posted by cmodica — 04 Nov 2022, 10:14
]]>2022-11-03T11:44:53+01:002022-11-03T11:44:53+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44433#p44433I know my patch doesn't answer your need, but can offer an alternative before something else comes out !
can you send a file with BWF via wetransfer so I can have look at the chunk inside it and see if it's easy to read the BWF infos ??
Statistics: Posted by oli_lab — 03 Nov 2022, 11:44
]]>2022-11-02T17:44:03+01:002022-11-02T17:44:03+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44428#p44428I can’t test because i am far away from my studio this week. But my question was not to export segments from Usine. But to import in an Usine sampler a wav file with markers inside it. Markers are write in the meta data of a BWF in Reapers for exemple, or an other DAW.
Statistics: Posted by cmodica — 02 Nov 2022, 17:44
]]>2022-11-02T17:18:16+01:002022-11-02T17:18:16+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44427#p44427I improved the patch with using some scripting. Now .mkrs files are save along the wavefiles (makes it easier to retrieved) enjoy !
save markers by script.pat
Statistics: Posted by oli_lab — 02 Nov 2022, 17:18
]]>2022-10-28T22:28:39+01:002022-10-28T22:28:39+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44412#p44412I did that with global arrays, that might help.
It's working but I still didn't figure out where the global arrays files are saved in my computer !
savemarkers.wkp
Statistics: Posted by oli_lab — 28 Oct 2022, 23:28
]]>2022-10-27T14:22:05+01:002022-10-27T14:22:05+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44407#p44407Statistics: Posted by Ariajazz — 27 Oct 2022, 15:22
BWF looks to be able to embed markers so maybe Senso would be able to import them. Maybe we could have a look on this. Sylvain
Yes, I think it should be an interesting improvement.
Forgive my ignorance... What is BWF?
Ignorance is when you don't ask for information about what you don't know yet.
BWF is Broadcast Wave File. These are metadata that are written with the wav file. This can be timecode, track name, markers, etc. BWF data are very much used by film sound engineers, but not only. There can be very useful.
Statistics: Posted by cmodica — 27 Oct 2022, 12:22
]]>2022-10-26T22:17:29+01:002022-10-26T22:17:29+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44404#p44404Statistics: Posted by Ariajazz — 26 Oct 2022, 23:17
]]>2022-10-26T12:14:26+01:002022-10-26T12:14:26+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44403#p44403Sylvain
Statistics: Posted by SylvainT — 26 Oct 2022, 13:14
]]>2022-10-26T03:22:07+01:002022-10-26T03:22:07+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44402#p44402Statistics: Posted by Ariajazz — 26 Oct 2022, 04:22
]]>2022-10-25T16:35:05+01:002022-10-25T16:35:05+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44400#p44400 Example: I put markers at specific moments of an audio file in Reaper. I then export this audio file with the Markers only option in the BWF menu. When I import this file into an HH sampler, the markers are present.
Statistics: Posted by cmodica — 25 Oct 2022, 17:35
]]>BrainModularBrainModular Users Forum2023-03-03T18:45:05+01:00https://brainmodular.org/forums/app.php/feed/topic/70552023-03-03T18:45:05+01:002023-03-03T18:45:05+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44728#p44728 please update the oli_lab_pack addon !
tell me !
cheers Olivar
savemarkers.wkp
]]>2022-10-27T11:22:35+01:002022-10-27T11:22:35+01:00https://brainmodular.org/forums/viewtopic.php?t=7055&p=44405#p44405
