ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2022-11-03T14:24:07+01:00 https://brainmodular.org/forums/app.php/feed/topic/7041 2022-11-03T14:24:07+01:00 2022-11-03T14:24:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=7041&p=44435#p44435 <![CDATA[Re: Threads]]> Statistics: Posted by senso — 03 Nov 2022, 14:24
2022-11-02T19:46:36+01:00 2022-11-02T19:46:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=7041&p=44430#p44430 <![CDATA[Re: Threads]]>
Statistics: Posted by x.iso — 02 Nov 2022, 19:46
2022-10-05T15:41:06+01:00 2022-10-05T15:41:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=7041&p=44338#p44338 <![CDATA[Re: Threas]]> Just FYI, polyphonic sub-patch could also now be multithreaded, but this is the same, be carrefull, it could be worth, depending on many parameters.
Those features could be very interesting in heavy processing, but you'll need to be deeply aware of multithreading and use them with tests.
Statistics: Posted by SylvainT — 05 Oct 2022, 16:41
2022-10-05T15:27:32+01:00 2022-10-05T15:27:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=7041&p=44337#p44337 <![CDATA[Re: Threas]]>
and sorry for the typing error...
Statistics: Posted by Gilsornette — 05 Oct 2022, 16:27
2022-10-05T15:33:52+01:00 2022-10-05T14:32:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=7041&p=44336#p44336 <![CDATA[Re: Threas]]>
This option has to be used carrefully.
You can use it effectively when you have a lot to calculate. If you have just one patch, this will not change anything, only for several patches. One thread per patch. But the reason to be carrefull is that you don't know the order of calculation. So it can't work if you have audio going from one patch to another below.
All the best
Statistics: Posted by SylvainT — 05 Oct 2022, 15:32
2022-10-05T14:08:00+01:00 2022-10-05T14:08:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=7041&p=44335#p44335 <![CDATA[Threads]]>
When shall we use the thread option in Rack Calculation Mode? Is it when there are lots of patches inside
or "big" patches with heavy cpu consumption? Or in other cases.
Thank you
Statistics: Posted by Gilsornette — 05 Oct 2022, 15:08
All the best
Thank you
