ArrayArrayArray BrainModular BrainModular Users Forum 2022-09-02T15:15:22+01:00 https://brainmodular.org/forums/app.php/feed/topic/7028 2022-09-02T15:15:22+01:00 2022-09-02T15:15:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=7028&p=44249#p44249 <![CDATA[Re: questions about save setup and devices]]> Thank you.
Statistics: Posted by cmodica — 02 Sep 2022, 16:15
2022-09-02T12:48:30+01:00 2022-09-02T12:48:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=7028&p=44248#p44248 <![CDATA[Re: questions about save setup and devices]]> But remember that Usine is a portable application so you can just copy + rename the Usine folder (or .app on MAC) and have several instances of Usine installed on your computer. Each instances has its own setup.
Personally I use this method, very efficient to be sure to retrieve proper settings on each project (not only audio).
Statistics: Posted by senso — 02 Sep 2022, 13:48
2022-09-02T11:07:38+01:00 2022-09-02T11:07:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=7028&p=44247#p44247 <![CDATA[questions about save setup and devices]]> 1- Is there any way to save the group of Devices with a project?
I have several projects at the same time that use different devives. For each project I save a group of devices that I load according to the project used.
I would like this device group to load automatically when I open the project.
Is this possible?
2- Is there a way to save the HH audio configuration with each project?
In the same way, my audio input/output configuration varies from project to project. Sometimes I use only inputs 1 and 2 and outputs 1-2, sometimes I use inputs 3-4-5 and ADAT outputs 1 to 8, etc.
So for each project I have to reconfigure the inputs and outputs of the HH audio setup.
Is it possible that these configurations are saved with the project?
3- Is there a way to read the name of the device group loaded in the Devices window title ?
Maybe this message should be in the suggestions part of this forum ?
Thank you very much.
Statistics: Posted by cmodica — 02 Sep 2022, 12:07
Is this possible?
