ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2022-05-02T12:12:23+02:00 https://brainmodular.org/forums/app.php/feed/topic/6982 2022-05-02T12:12:23+02:00 2022-05-02T12:12:23+02:00 https://brainmodular.org/forums/viewtopic.php?t=6982&p=44026#p44026 <![CDATA[Re: Midi Control problem after saving]]> I will take time to do this soon.
Thanks again !
Statistics: Posted by JF — 02 May 2022, 12:12
2022-05-02T10:48:39+02:00 2022-05-02T10:48:39+02:00 https://brainmodular.org/forums/viewtopic.php?t=6982&p=44025#p44025 <![CDATA[Re: Midi Control problem after saving]]> Statistics: Posted by senso — 02 May 2022, 10:48
2022-05-01T23:51:44+02:00 2022-05-01T23:51:44+02:00 https://brainmodular.org/forums/viewtopic.php?t=6982&p=44024#p44024 <![CDATA[Re: Midi Control problem after saving]]> It's quite hard because all my workspace is based on the send and the midi assignations .. If I can't be confident on the save... I loose a lot of time trying assign midi for nothing.
I would be very grateful if you can help me for this.
Statistics: Posted by JF — 01 May 2022, 23:51
2022-05-01T17:43:53+02:00 2022-05-01T17:43:53+02:00 https://brainmodular.org/forums/viewtopic.php?t=6982&p=44023#p44023 <![CDATA[Re: Midi Control problem after saving]]> Thanks for the answer.
Unfortunately it doesn't change. It's a bit random. If I change the order for the outputs (adding an output for example) the midi assignments change too. There is something that we have to do not to have this kind of problem ?
Statistics: Posted by JF — 01 May 2022, 17:43
2022-04-28T11:29:35+02:00 2022-04-28T11:29:35+02:00 https://brainmodular.org/forums/viewtopic.php?t=6982&p=44014#p44014 <![CDATA[Re: Midi Control problem after saving]]> Statistics: Posted by senso — 28 Apr 2022, 11:29
2022-04-26T11:12:45+02:00 2022-04-26T11:12:45+02:00 https://brainmodular.org/forums/viewtopic.php?t=6982&p=44009#p44009 <![CDATA[Midi Control problem after saving]]> I did a workspace with lot of sends (Rack to rack). Each send is controlled by a faderfox but for an unknown reason some racks don't keep the midi assignation for the sends after saving the workspace. When I open the workspace again, it lost the assignation.
I don't understand because I did the same for other racks and it works fine.
Any idea ?
Thanks !
Statistics: Posted by JF — 26 Apr 2022, 11:12
Thanks again !
Any idea ?
Thanks !
