ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2022-02-21T00:55:34+01:00 https://brainmodular.org/forums/app.php/feed/topic/6962 2022-02-21T00:55:34+01:00 2022-02-21T00:55:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=6962&p=43961#p43961 <![CDATA[Re: Touch Screen Recommendation for Usine]]>
not tested, and I'm afraid of the weight of the support.
The two above haven't a support so are light.
thanks!
Statistics: Posted by pepeflores — 21 Feb 2022, 00:55
2022-02-19T09:13:39+01:00 2022-02-19T09:13:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=6962&p=43960#p43960 <![CDATA[Re: Touch Screen Recommendation for Usine]]> The two above haven't a support so are light.
Statistics: Posted by senso — 19 Feb 2022, 09:13
2022-02-18T14:09:59+01:00 2022-02-18T14:09:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=6962&p=43959#p43959 <![CDATA[Re: Touch Screen Recommendation for Usine]]>
a portable : https://www.amazon.fr/WIMAXIT-Couvercle ... C52&sr=8-7
a big : https://www.amazon.fr/Hanns-ht225hpb-5z ... B01F3636V0
We can't confirm that it will works with your Wacom Cintiq, not tested.
The full implementation of wacom tablets will be available in the next major release.
Thanks for letting me know this.
Have you tested Usine with this one?
Dell 24 Touch Monitor - P2418HT
Statistics: Posted by pepeflores — 18 Feb 2022, 14:09
2022-02-14T08:00:02+01:00 2022-02-14T08:00:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=6962&p=43949#p43949 <![CDATA[Re: Touch Screen Recommendation for Usine]]> https://www.amazon.fr/WIMAXIT-Couvercle ... C52&sr=8-7
Statistics: Posted by senso — 14 Feb 2022, 08:00
2022-02-13T14:33:48+01:00 2022-02-13T14:33:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=6962&p=43948#p43948 <![CDATA[Touch Screen Recommendation for Usine]]> I am new to Usine.
Just testing the app at the momment.
I have quite a few questions but I will start with this one:
Can someone recommend a good touch screen to work with Usine on Win 10?
Can someone confirm if I can use a Wacom Cintiq 16 with Usine performance interface as well?
Thanks!
p.
Statistics: Posted by pepeflores — 13 Feb 2022, 14:33
thanks!
Thanks!
p.
