ArrayArrayArray BrainModular BrainModular Users Forum 2022-01-03T10:28:25+01:00 https://brainmodular.org/forums/app.php/feed/topic/6940 2022-01-03T10:28:25+01:00 2022-01-03T10:28:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=6940&p=43850#p43850 <![CDATA[Re: plugin manager fxp/fxb direct load/save]]> Statistics: Posted by senso — 03 Jan 2022, 10:28
2021-12-30T02:04:18+01:00 2021-12-30T02:04:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=6940&p=43841#p43841 <![CDATA[Re: plugin manager fxp direct load/save]]>
I have just set up a subpatch containing Pianoteq VST and saved the subpatch poly 1 preset direct to a file.
I tried to load the preset file into subpatch poly 2 and it did not work.
I then looked in the 2 preset files.
They are like:
[VERSION]
save version=115
usine version=HH5
date usine=211124
[6977464658333720400]
The number in brackets is presumably an ID to make sure you a reloading into the same patch.
If I change the ID to that of poly 2, the preset from poly 1 will then load into poly 2.
I understand the ID is there to protect usine where loading a preset that was saved from a completely different patch could cause chaos ?
So I think we need some special Polyphony support that would allow a patch from one Poly voice to load into another Poly voice.
Perhaps a list of alternate IDs (from all the poly voices) could be put in the patch file ?
It would make sense to only allow the duplicate IDs for items that are the same in all the poly voices - Usine would obviously have that information.
Simon.
Statistics: Posted by sm_jamieson — 30 Dec 2021, 02:04
2021-12-30T20:14:13+01:00 2021-12-29T23:40:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=6940&p=43840#p43840 <![CDATA[plugin manager fxp/fxb direct load/save]]> appears to specify the file to be saved or loaded.
Could the plugin manager load/save be given a direct file load/save option (like the HH5 preset manager has for direct-to-file) ?
I know I could save the VST settings with a Usine preset of the patch containing the VST, but that would mean restructuring my
workspace to put each VST instance into a separate subpatch.
Simon.
Statistics: Posted by sm_jamieson — 29 Dec 2021, 23:40
They are like:
[VERSION]
save version=115
usine version=HH5
date usine=211124
Simon.
Simon.
