ArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2021-05-24T22:13:13+01:00https://brainmodular.org/forums/app.php/feed/topic/68112021-05-24T22:13:13+01:002021-05-24T22:13:13+01:00https://brainmodular.org/forums/viewtopic.php?t=6811&p=43379#p43379WIFI can be tricky ! here's what I do with OSC when I need reliability : switch send message once press and depress, AND send message every second when not pressed.
Statistics: Posted by oli_lab — 24 May 2021, 23:13
]]>2021-03-22T21:59:00+01:002021-03-22T21:59:00+01:00https://brainmodular.org/forums/viewtopic.php?t=6811&p=43294#p43294 I'll use Wifi and Wifi is poor a network. I can't have cables everywhere If I understand good, I'll must waiting for the next version of Usine? Have you got an idea of the date for this new release?
Statistics: Posted by stefkpl06 — 22 Mar 2021, 21:59
]]>2021-03-22T18:52:41+01:002021-03-22T18:52:41+01:00https://brainmodular.org/forums/viewtopic.php?t=6811&p=43292#p43292Statistics: Posted by senso — 22 Mar 2021, 18:52
2021-03-21T17:24:40+01:002021-03-21T17:24:40+01:00https://brainmodular.org/forums/viewtopic.php?t=6811&p=43286#p43286 I just want to send byte(s) and receive byte(s).
For exemple, if I design a wireless object. I would like send and receive simple command with acknowledgement from TCP low level socket. In UDP, I must implement ack and I can have some packets lost:( so I'm not sure if the command is ok.
The best thing for me will can be, target IP/Port and source IP/Port with is data like this : PARAM INT(64bits) / VALUE INT(64bits).
Am I clear?
Thank's
Note, I can't use OSC protocole for the same reason.
Statistics: Posted by stefkpl06 — 21 Mar 2021, 17:24
]]>2021-03-21T10:29:24+01:002021-03-21T10:29:24+01:00https://brainmodular.org/forums/viewtopic.php?t=6811&p=43283#p43283Actually there is no TCP in Usine, but planed in future versions.
]]>2021-03-20T12:40:06+01:002021-03-20T12:40:06+01:00https://brainmodular.org/forums/viewtopic.php?t=6811&p=43277#p43277I need for my project a simple TCP module who can send and receive some bytes, like the UDP module, but not in UDP because I can't have real acknowledgement. How can I do this ? Have you got a solution?
Best regards
Statistics: Posted by stefkpl06 — 20 Mar 2021, 12:40
]]>BrainModularBrainModular Users Forum2021-05-24T22:13:13+01:00https://brainmodular.org/forums/app.php/feed/topic/68112021-05-24T22:13:13+01:002021-05-24T22:13:13+01:00https://brainmodular.org/forums/viewtopic.php?t=6811&p=43379#p43379WIFI can be tricky ! here's what I do with OSC when I need reliability : switch send message once press and depress, AND send message every second when not pressed.
]]>2021-03-21T17:24:40+01:002021-03-21T17:24:40+01:00https://brainmodular.org/forums/viewtopic.php?t=6811&p=43286#p43286 I just want to send byte(s) and receive byte(s).
Am I clear?
Thank's
Best regards
