ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2021-03-20T18:33:45+01:00https://brainmodular.org/forums/app.php/feed/topic/67862021-03-20T18:33:45+01:002021-03-20T18:33:45+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43281#p43281Statistics: Posted by Gilsornette — 20 Mar 2021, 18:33
2021-03-19T19:44:52+01:002021-03-19T19:44:52+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43273#p43273Statistics: Posted by senso — 19 Mar 2021, 19:44
]]>2021-03-19T13:19:28+01:002021-03-19T13:19:28+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43270#p43270
Merci Joffo. J'ai eu la même idée et je cherche actuellement avec le module Data Manipulation Rec XY. Mais je n'ai pas encore trouvé la solution idéale:-)
Statistics: Posted by Gilsornette — 19 Mar 2021, 13:19
]]>2021-03-18T23:09:03+01:002021-03-18T23:09:03+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43266#p43266C'est un peu du dépannage mais tu peux essayer de voir si tu trouve un moyen de faire quelque chose avec cet exemple.
(This is a bit of a tricky exercise but you can try to see if you can find a way to do something with this example.)
Statistics: Posted by joffo78 — 18 Mar 2021, 23:09
]]>2021-03-15T12:57:31+01:002021-03-15T12:57:31+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43254#p43254Statistics: Posted by Gilsornette — 15 Mar 2021, 12:57
]]>2020-12-22T14:15:22+01:002020-12-22T14:15:22+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43151#p43151
Statistics: Posted by Malenki — 22 Dec 2020, 14:15
Statistics: Posted by cmodica — 22 Dec 2020, 12:19
]]>2020-12-21T20:01:58+01:002020-12-21T20:01:58+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43148#p43148Road map is very heavy, but ti could be in the pipe
Statistics: Posted by SylvainT — 21 Dec 2020, 20:01
]]>2020-12-18T12:01:58+01:002020-12-18T12:01:58+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43142#p43142Statistics: Posted by cmodica — 18 Dec 2020, 12:01
]]>2020-12-17T22:08:37+01:002020-12-17T22:08:37+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43141#p43141Je mix en live des instruments en multidiffusion via SpatRévolution. J’aimerais pouvoir écrire des automations via un contrôleur midi ou OSC, sans passer par la souris, se serait un gain de temps.
Et un autre besoin : lors de l’enregistrement d’une automation/élément, on peut ensuite la glissée dans la grid. L’idéal serait de pouvoir enregistrer un autre état du même paramètre, tout en conservant l’état précédent dans la grid, et empiler ainsi de suite des automations dans la grid. J’espère que c’est compréhensible
Statistics: Posted by Malenki — 17 Dec 2020, 22:08
]]>BrainModularBrainModular Users Forum2021-03-20T18:33:45+01:00https://brainmodular.org/forums/app.php/feed/topic/67862021-03-20T18:33:45+01:002021-03-20T18:33:45+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43281#p43281Statistics: Posted by Gilsornette — 20 Mar 2021, 18:33
]]>2021-03-19T19:44:52+01:002021-03-19T19:44:52+01:00https://brainmodular.org/forums/viewtopic.php?t=6786&p=43273#p43273Statistics: Posted by senso — 19 Mar 2021, 19:44
