ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2020-11-19T08:35:15+01:00https://brainmodular.org/forums/app.php/feed/topic/67752020-11-19T08:35:15+01:002020-11-19T08:35:15+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43092#p43092The possibility to use it offline is really a must have in my opinion. Especially with students ( computers in music conservatory and school are often offline)
Statistics: Posted by damstraversaz — 19 Nov 2020, 08:35
]]>2020-11-16T08:49:12+01:002020-11-16T08:49:12+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43073#p43073Thank you for your quick replies
Statistics: Posted by Gilsornette — 16 Nov 2020, 08:49
]]>2020-11-16T07:15:45+01:002020-11-16T07:15:45+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43072#p43072Statistics: Posted by rlgsbt — 16 Nov 2020, 07:15
2020-11-15T18:03:13+01:002020-11-15T18:03:13+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43070#p43070 I return to my previous problem. Path Groove is correctly running when loaded from Motionkit directory but it's not the case for some others. E.g. Ringtone, additive, droid... Some data values are 0 and should be something else (Const, / amplitude in Droid...) , so the patch is not running correctly
Statistics: Posted by Gilsornette — 15 Nov 2020, 18:03
]]>2020-11-15T17:19:22+01:002020-11-15T17:19:22+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43069#p43069...but it work anyway offline with the cache memory of your Internet Navigator if you ran it online before
]]>2020-11-15T15:37:13+01:002020-11-15T15:37:13+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43068#p43068Is it possible to download PoseNet, and to run it offline?
Statistics: Posted by Gilsornette — 15 Nov 2020, 15:37
]]>2020-11-15T15:34:54+01:002020-11-15T15:34:54+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43067#p43067 If I open the workspace from Motionkit directory it works correctly. It solves my problem, thank you!
Statistics: Posted by Gilsornette — 15 Nov 2020, 15:34
]]>2020-11-14T18:01:21+01:002020-11-14T18:01:21+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43066#p43066Have you also tried to open the Musinekit version (ie. Homing Pad) ? from addons or directly from \MusineKit_Windows_2.31\Deploy\b - Workspaces\Homing Pad.wkp It's quite the same wkp.
]]>2020-11-14T11:28:17+01:002020-11-14T11:28:17+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43065#p43065Clicking on the window makes samples boxes disappear. Some faders values are not correct. i.e tempo is 0 to 1, also for sample's fader.
Statistics: Posted by Gilsornette — 14 Nov 2020, 11:28
]]>2020-11-14T11:12:51+01:002020-11-14T11:12:51+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43064#p43064I'll have a look again. Thank you
Statistics: Posted by Gilsornette — 14 Nov 2020, 11:12
]]>2020-11-14T07:57:03+01:002020-11-14T07:57:03+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43063#p43063You also can move the ball with 2 BUS X and Y (look at the XY pad).
]]>2020-11-13T22:20:21+01:002020-11-13T22:20:21+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43062#p43062I've imported PathGroove in Usine but it doesn't start reading (moving), do you have an idea about what I'm missing?
Statistics: Posted by Gilsornette — 13 Nov 2020, 22:20
]]>2020-11-13T19:30:57+01:002020-11-13T19:30:57+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43061#p43061If you want to edit Motionkit's patches, you have to do it via Usine. Some module will probably miss (not yet implemented in HH4), but you can also edit the older version of MusineKit without problem.
]]>2020-11-13T18:32:14+01:002020-11-13T18:32:14+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43060#p43060 Is there a way to edit Motionkit's patches inside Motionkit interface or should I save them and import them in Usine to do some modifications? Thank you
Statistics: Posted by Gilsornette — 13 Nov 2020, 18:32
]]>BrainModularBrainModular Users Forum2020-11-19T08:35:15+01:00https://brainmodular.org/forums/app.php/feed/topic/67752020-11-19T08:35:15+01:002020-11-19T08:35:15+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43092#p43092The possibility to use it offline is really a must have in my opinion. Especially with students ( computers in music conservatory and school are often offline)
]]>2020-11-15T18:03:13+01:002020-11-15T18:03:13+01:00https://brainmodular.org/forums/viewtopic.php?t=6775&p=43070#p43070 I return to my previous problem. Path Groove is correctly running when loaded from Motionkit directory but it's not the case for some others. E.g. Ringtone, additive, droid... Some data values are 0 and should be something else (Const, / amplitude in Droid...) , so the patch is not running correctly
