ArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2020-12-13T00:06:46+01:00 https://brainmodular.org/forums/app.php/feed/topic/6770 2020-12-13T00:06:46+01:00 2020-12-13T00:06:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=6770&p=43131#p43131 <![CDATA[Re: Workspace Grid Alignment (For Modular mode)]]> Statistics: Posted by x.iso — 13 Dec 2020, 00:06
2020-12-12T23:59:29+01:00 2020-12-12T23:59:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=6770&p=43130#p43130 <![CDATA[Re: Workspace Grid Alignment (For Modular mode)]]>
here's example, all racks have 'show in IB' checked, but for proposed mode all racks should be shown
I've set IB to auto-organize and it did neatly pack racks together, but in some specific order. so the current problem with this approach is that you can't move those racks around so they snap in place in different order, when I activate unlock UI, I can move rack, but it just snaps back to where it was as long as auto-organize is active. Instead we need to be able to re-arrange those racks like modules in Bitwig's Grid, but not necessarily snapping to actual grid, just adjacent racks with specified margins.
Statistics: Posted by x.iso — 12 Dec 2020, 23:59
2020-11-06T08:36:03+01:00 2020-11-06T08:36:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=6770&p=43050#p43050 <![CDATA[Re: Workspace Grid Alignment (For Modular mode)]]>
Statistics: Posted by nay-seven — 06 Nov 2020, 08:36
2020-11-06T07:26:12+01:00 2020-11-06T07:26:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=6770&p=43049#p43049 <![CDATA[Re: Workspace Grid Alignment (For Modular mode)]]>
Statistics: Posted by SylvainT — 06 Nov 2020, 07:26
2020-11-05T08:55:49+01:00 2020-11-05T08:55:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=6770&p=43046#p43046 <![CDATA[Re: Workspace Grid Alignment (For Modular mode)]]> Statistics: Posted by nay-seven — 05 Nov 2020, 08:55
2020-11-05T06:52:24+01:00 2020-11-05T06:52:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=6770&p=43045#p43045 <![CDATA[Re: Workspace Grid Alignment (For Modular mode)]]> I understand the first and second points but isn't quite it,
If racks could be moved around on a grid that would be perfect
Statistics: Posted by eartubes — 05 Nov 2020, 06:52
2020-11-01T22:39:50+01:00 2020-11-01T22:39:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=6770&p=43044#p43044 <![CDATA[Re: Workspace Grid Alignment (For Modular mode)]]>
For your questions, if I understand :
- first of all, when you put rack in the grid, you can deactivate "show when active on grid". Like that, your rack will not collapse on the left of your screen.
- then, you can use the IB mode also, there you can have a free-form and snap to grid layout. Unfortunately, for now, just the patches could be moved. I ask Senso if it could do something for the racks easily.
Hope it helps.
Statistics: Posted by SylvainT — 01 Nov 2020, 22:39
2020-11-01T03:18:04+01:00 2020-11-01T03:18:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=6770&p=43043#p43043 <![CDATA[Workspace Grid Alignment (For Modular mode)]]> an open issue since 2013) support touch screens while I can just make my own easily in Usine's interface, all literally at my fingertips!
One thing I haven't been able to figure out is how to enable a free-form (and snap to grid) workspace layout, like I can do in the patching window. I've tried disabling the auto-reorganise feature, but it seems the workspace, or at least modular patches are auto-aligned and the only way to rearrange them is by dragging rack/component titles ontop of another.
Bitwig's Polygrid has the right idea, allowing the user to drag modular components on a freeform snap-to-grid "infinite" canvas, it seems Usine Hollyhock should have this capability since it's literally a "build your own DAW" DAW, and I can manually configure everything else, I can rearrange the layout using the left and right slides, although abit cumbersome.
I think this is important because the layout of patches in Modular mode contributes to the experience of organizing your wires and allows you to visually group related components to some concept, like you would do in patching.
Edit:
Another option is to have modular patches in horizontal (or even vertical) racks like other patches
Statistics: Posted by eartubes — 01 Nov 2020, 03:18
Hope it helps.
Edit:
