i test with a sampler to simplify, but in the final patch, the audio In will come from an external source.
Statistics: Posted by cmodica — 03 Jul 2020, 15:13
]]>2020-06-27T09:34:49+01:002020-06-27T09:34:49+01:00https://brainmodular.org/forums/viewtopic.php?t=6703&p=42646#p42646I will try as soon as i can and i will tell you.
Statistics: Posted by cmodica — 27 Jun 2020, 10:34
]]>2020-06-25T18:05:39+01:002020-06-25T18:05:39+01:00https://brainmodular.org/forums/viewtopic.php?t=6703&p=42637#p42637Sometimes it's also simplier to use mixer modules than surround panner for surround trajectories (and more CPU friendly).
All the best
Statistics: Posted by SylvainT — 25 Jun 2020, 19:05
]]>2020-06-25T17:05:16+01:002020-06-25T17:05:16+01:00https://brainmodular.org/forums/viewtopic.php?t=6703&p=42636#p42636 For example : I hit a cymbal. when the sound is louder than a specific volume, we can ear it on speaker 1 when the sound decrease and the volume is under the specific volume, we can ear it on speaker 3.
I'd like to have the possibility to change the placement more or less speed.
I try with an Envelope Follower and a Trajectory surround pan with a trigger to play trajectory. But it doesn't do the job correctely. I'm sure it is not a complex patching work, but there is something that i can't find.
Statistics: Posted by cmodica — 25 Jun 2020, 18:05
All the best
