ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2020-05-18T19:23:27+01:00 https://brainmodular.org/forums/app.php/feed/topic/6678 2020-05-18T19:23:27+01:00 2020-05-18T19:23:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=6678&p=42561#p42561 <![CDATA[Re: Remote saving new preset?]]>
Statistics: Posted by Djordjo — 18 May 2020, 20:23
2020-05-07T21:23:16+01:00 2020-05-07T21:23:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=6678&p=42503#p42503 <![CDATA[Re: Remote saving new preset?]]> Statistics: Posted by Djordjo — 07 May 2020, 22:23
2020-05-07T20:42:37+01:00 2020-05-07T20:42:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=6678&p=42502#p42502 <![CDATA[Re: Remote saving new preset?]]> Statistics: Posted by nay-seven — 07 May 2020, 21:42
2020-05-07T20:35:25+01:00 2020-05-07T20:35:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=6678&p=42501#p42501 <![CDATA[Re: Remote saving new preset?]]>
You're right, the preset was first in Usine and for compatibility with older patches, it is still there. Actually, in 99% of situations, you don't need it anymore. You have presets for patches, racks and workspaces.
Unfortunately, we can't actually create a new preset dynamicaly. It' a good suggestion. I'll speak with Senso tomorrow, I will suggest. Probably not a big deal, so I hope the next release will do the job.
Statistics: Posted by SylvainT — 07 May 2020, 21:35
2020-05-07T13:30:43+01:00 2020-05-07T13:30:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=6678&p=42500#p42500 <![CDATA[Remote saving new preset?]]>
I created a nice recording channel strip in Usine with some vocal manipulation plugins and now i want to make an iPad Interface for it.
First thing, i can't find an answer for how to remote control the (new) button for a preset.
The idea is I work with the iPad, do some settings and press the button for new preset without touching Usine,
and i get a new preset at the end of the preset list. That's it.
If i right click on the (next) and (previous) buttons I have an option to assign a remote control, but not for (new), (write) and (list).
I saw in the manual that there are modules named: (Preset Manager) and (Preset Settings).
When I open the (Preset Manager), I find it confusing that i'm forced to decide how much presets I want. Well, I don't know, let's say ten?!
Oh, wait, maybe I need more. Too late its already created. - I'm joking, but why this limitation?
The (Preset Manager) has an input trigger called (new/rewrite). When I create a button to trigger it, it creates a preset. If i press it again, it stays
on the preset and rewrites it, i guess. So I have to determine, what's the current preset number, do +1 and save the new one?
What if I already have some presets, like 5, stopped and the 3rd, did my edits and wanne save the the result as a new preset?
How can I determine where the next "empty" preset slot is?
All I want is that the (new) preset works like in the - built in one - for every patch.
I remote press it and a new preset is added at the end of the preset list.
BTW I don't understand the relation between the patch built in preset manager and the (Preset Manager) module.
If I create a Preset Manger in a patch it's basically the same. Is this historically grown. like first there was the (Preset Manger) module
then HH made it standard for every patch?
Best Regards
Djordjo
Statistics: Posted by Djordjo — 07 May 2020, 14:30
Best Regards
Djordjo
