ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2020-04-09T15:32:20+01:00 https://brainmodular.org/forums/app.php/feed/topic/6656 2020-04-09T15:32:20+01:00 2020-04-09T15:32:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42390#p42390 <![CDATA[Re: Looper type Ableton Live]]> Statistics: Posted by Malenki — 09 Apr 2020, 16:32
2020-04-09T12:52:32+01:00 2020-04-09T12:52:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42388#p42388 <![CDATA[Re: Looper type Ableton Live]]> Statistics: Posted by joffo78 — 09 Apr 2020, 13:52
2020-04-09T12:49:07+01:00 2020-04-09T12:49:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42387#p42387 <![CDATA[Re: Looper type Ableton Live]]>
En tout cas c'est exactement ça.
Statistics: Posted by Malenki — 09 Apr 2020, 13:49
2020-04-09T11:46:55+01:00 2020-04-09T11:46:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42386#p42386 <![CDATA[Re: Looper type Ableton Live]]> Statistics: Posted by joffo78 — 09 Apr 2020, 12:46
2020-04-09T11:45:19+01:00 2020-04-09T11:45:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42385#p42385 <![CDATA[Re: Looper type Ableton Live]]> Statistics: Posted by joffo78 — 09 Apr 2020, 12:45
2020-04-09T11:32:32+01:00 2020-04-09T11:32:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42384#p42384 <![CDATA[Re: Looper type Ableton Live]]> À la vue de ce que tu m'as proposé hier j'ai l'impression de devoir créer beaucoup d'évènements sur la grille. Je vais creuser d'avantage et me forcer à penser différemment de "Live".
Statistics: Posted by Malenki — 09 Apr 2020, 12:32
2020-04-08T18:32:39+01:00 2020-04-08T18:32:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42380#p42380 <![CDATA[Re: Looper type Ableton Live]]> Pourquoi cherches tu à passer par des patchs ? La grille est faite pour ça ...
Statistics: Posted by joffo78 — 08 Apr 2020, 19:32
2020-04-08T16:31:04+01:00 2020-04-08T16:31:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42379#p42379 <![CDATA[Re: Looper type Ableton Live]]> Je vais faire comme ça en attendant de comprendre comment fabriquer le patch qui exécuterait tout ça de manière automatiser. Ça sent le gros dossier....
Merci encore pour ton aide
Statistics: Posted by Malenki — 08 Apr 2020, 17:31
2020-04-08T09:51:38+01:00 2020-04-08T09:51:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42376#p42376 <![CDATA[Re: Looper type Ableton Live]]> Ctril+G pour ouvrir la grille.
Statistics: Posted by joffo78 — 08 Apr 2020, 10:51
2020-04-08T09:28:17+01:00 2020-04-08T09:28:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42375#p42375 <![CDATA[Re: Looper type Ableton Live]]> Tu créer un sampler recorder et tu places le switch rec dans la grille . Tu quantizes les sections où tu désires effectuer ton action et le tour est joué.
Je vais essayer de te construire un exemple
Statistics: Posted by joffo78 — 08 Apr 2020, 10:28
2020-04-07T16:39:26+01:00 2020-04-07T16:39:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42374#p42374 <![CDATA[Re: Looper type Ableton Live]]> La façon la plus commune que j'ai d'utiliser le looper de Live :
Un instrument joué sur le plateau donc une entrée dans un piste et je crée la boucle sur un nombre de mesures ou de temps prédéfini.
2 possibilités :
- soit le boucleur s'arrêt automatiquement d'enregistrer (arrivée à la fin du cycle prédéfini) et passe en lecture
-soit il passe en overdub et j'arrête l'enregistrement à la fin du nombre de boucles empilées voulues, bien sûr la lecture des boucles continues
j'espère être clair.
encore merci
Statistics: Posted by Malenki — 07 Apr 2020, 17:39
2020-04-06T15:54:12+01:00 2020-04-06T15:54:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42371#p42371 <![CDATA[Re: Looper type Ableton Live]]> commençont par faire un topos sur tes besoins.
Statistics: Posted by joffo78 — 06 Apr 2020, 16:54
2020-04-03T18:41:28+01:00 2020-04-03T18:41:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=6656&p=42368#p42368 <![CDATA[Looper type Ableton Live]]> Je suis régisseur son, et gros débutant sur Usine.
J’ai beau avoir passer beaucoup de temps à fouiller le forum et Google. Bon, je suis peut-être un peu quiche :oops:
Je galère à trouver un looper, du type de celui de Ableton. Ça fait des années que je fais mes conduites sur Live. Les loopers, que j’ai trouvés sont trop compliqué, utiliser.
Je suis vraiment fan de la grille de Usine pour les conduites de spectacles, c’est le seul truc qui manque afin de switcher définitivement sur Usine.
J’ai tenté de faire un patch, sans grand résultat.
Si une bonne âme peut me venir en aide.
Statistics: Posted by Malenki — 03 Apr 2020, 19:41
2 possibilités :
encore merci
