ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2020-05-02T01:30:31+02:00 https://brainmodular.org/forums/app.php/feed/topic/6646 2020-05-02T01:30:31+02:00 2020-05-02T01:30:31+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42470#p42470 <![CDATA[Re: Collaborative MIDI over the internet]]> Statistics: Posted by x.iso — 02 May 2020, 01:30
2020-05-01T11:59:11+02:00 2020-05-01T11:59:11+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42468#p42468 <![CDATA[Re: Collaborative MIDI over the internet]]> http://www.netpd.org
It's a system built in Pure Data (vanilla) that creates a set of synchronised sequencers and instruments using OSC across remote computers.
Sending audio / midi / (osc?) into it from Brain Modular is totally possible. (route audio with soundflower or something similar)
Not that many people jamming on it at the moment but spread the word!
(Artsmesh has proved too complicated for me!)
Statistics: Posted by bmartin — 01 May 2020, 11:59
2020-04-16T10:31:57+02:00 2020-04-16T10:31:57+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42411#p42411 <![CDATA[Re: Collaborative MIDI over the internet]]> https://www.artsmesh.com/ for collaborative sound and OSC over the internet
I'll see if I can get it going with BrainModular OSC output
Statistics: Posted by bmartin — 16 Apr 2020, 10:31
2020-04-12T19:07:28+02:00 2020-04-12T19:07:28+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42397#p42397 <![CDATA[Re: Collaborative MIDI over the internet]]> Statistics: Posted by x.iso — 12 Apr 2020, 19:07
2020-04-11T11:46:11+02:00 2020-04-11T11:46:11+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42392#p42392 <![CDATA[Re: Collaborative MIDI over the internet]]>
If you want to find your public IP address (what people will need to find you over the internet): use http://ip4.me
To find your local IP address (the address of your computer beyond than the router): on a mac go to System Preferences, Network, and it should say 'Wifi is connected to [the router name] and has the IP address: 192 [.......]" This will probably be dynamic and need checking each session
You will need to set up 'port forwarding' for your router to get the connections going to the local ports (different procedure for each service provider) getting ports 5004 and 5005 forwarded to the same ports on the local machine.
You will need to tweak Firewall settings or temporarily switch it off.
Have had some limited success sending MIDI like this using the mac's Network MIDI session in Audio/Midi Settings (erratic latency and problems with feedback loops) but haven't been able to try BrainModular's 'sharing' possibilities yet.
This was useful: https://www.deepsignalstudios.com/rtp-m ... r-internet
Statistics: Posted by bmartin — 11 Apr 2020, 11:46
2020-03-27T23:42:46+02:00 2020-03-27T23:42:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42353#p42353 <![CDATA[Re: Collaborative MIDI over the internet]]> Statistics: Posted by bmartin — 27 Mar 2020, 22:42
2020-03-26T22:30:26+02:00 2020-03-26T22:30:26+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42343#p42343 <![CDATA[Re: Collaborative MIDI over the internet]]> Statistics: Posted by x.iso — 26 Mar 2020, 21:30
2020-03-26T22:14:03+02:00 2020-03-26T22:14:03+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42342#p42342 <![CDATA[Re: Collaborative MIDI over the internet]]> https://www.brainmodular.com/manuals/hh ... te-control
also this should work on HH4 (haven't found this on new manual, probably because it's demostrated on a different version of Usine)
https://www.brainmodular.com/manuals/hh ... re-patches
Statistics: Posted by x.iso — 26 Mar 2020, 21:14
2020-03-26T17:33:12+02:00 2020-03-26T17:33:12+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42341#p42341 <![CDATA[Re: Collaborative MIDI over the internet]]> Statistics: Posted by bmartin — 26 Mar 2020, 16:33
2020-03-26T10:25:46+02:00 2020-03-26T10:25:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42339#p42339 <![CDATA[Re: Collaborative MIDI over the internet]]> Statistics: Posted by x.iso — 26 Mar 2020, 09:25
2020-03-25T17:43:57+02:00 2020-03-25T17:43:57+02:00 https://brainmodular.org/forums/viewtopic.php?t=6646&p=42338#p42338 <![CDATA[Collaborative MIDI over the internet]]>
In this strange time of self-isolation I am probably not the only one looking for ways to make live music with others over the internet. I have never found a good way to do this due to problems like latency, glitches, etc. A normal 'jam' seems pretty much impossible but I wondered if there might be some possibilities for things like looping midi with HH/BrainModular that might be interesting.
The first idea that occurs to me is exploiting the Piano Roll array output - if this array could be sent over the internet to someone running a setup with a Piano Roll set to receive an array, with the same arrangement going back the other way, then two (or more) people could work on a sequence together (perhaps with the same midi data triggering entirely different sounds for each person). The array could be sent every bar and as it arrives with its own abstract time data it would not be spoilt by latency issues.
I've made a start on this but I don't know how to get the array into a format that can be output from HH/BM to travel via something like the Mac Network MIDI handler. I've tried to encapsulate the array as sysex data but so far it doesn't work.
Anyone else interested in finding a way of doing this sort of thing?
Statistics: Posted by bmartin — 25 Mar 2020, 16:43
