Statistics: Posted by nay-seven — 11 Jan 2020, 09:56
]]>2020-01-10T20:37:35+01:002020-01-10T20:37:35+01:00https://brainmodular.org/forums/viewtopic.php?t=6601&p=42055#p42055Statistics: Posted by x.iso — 10 Jan 2020, 20:37
2020-01-10T14:57:45+01:002020-01-10T14:57:45+01:00https://brainmodular.org/forums/viewtopic.php?t=6601&p=42051#p42051How did I miss that
Statistics: Posted by sm_jamieson — 10 Jan 2020, 14:57
Statistics: Posted by nay-seven — 10 Jan 2020, 12:53
]]>2020-01-10T12:12:25+01:002020-01-10T12:12:25+01:00https://brainmodular.org/forums/viewtopic.php?t=6601&p=42047#p42047Select your module , type "recreate" in the contextual menu, choose the right number of inlets/ourlets, and decide or not to keep your preferences. It's done
Statistics: Posted by SylvainT — 10 Jan 2020, 12:12
]]>2020-01-10T11:42:14+01:002020-01-10T11:42:14+01:00https://brainmodular.org/forums/viewtopic.php?t=6601&p=42044#p42044If you then want to change the Query options, you have to delete the module and re-drop it, thus losing all your connections.
I would like an option that allows you to change the Query options but keep all existing connections (unless some pins disappear due to change of Query of course). This could be in the context menu. I know this is possible as when you recompile an SDK user module and add inputs, all the existing inputs remain (the pin connections are store against parameter name).
So, for example, you have a patch with a selector module with 8 inputs. You realise you needed 16 inputs. Instead of deleting the module, re-dropping and reconnecting, you just re-run the Query, the module gets its new inputs - and you are happy ! I expect reloading the whole patch would be part of this process - fair enough.
(Sorry if this has been done in HH4)
Statistics: Posted by sm_jamieson — 10 Jan 2020, 11:42
]]>2020-01-10T14:57:45+01:002020-01-10T14:57:45+01:00https://brainmodular.org/forums/viewtopic.php?t=6601&p=42051#p42051How did I miss that
