ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2019-11-26T18:25:03+01:00https://brainmodular.org/forums/app.php/feed/topic/65702019-11-26T18:25:03+01:002019-11-26T18:25:03+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41918#p41918Statistics: Posted by Gilsornette — 26 Nov 2019, 18:25
2019-11-26T13:30:04+01:002019-11-26T13:30:04+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41917#p41917Here's a small patch for an automatic remote with the BCF You can put it in a device.
Automatic BCF Remote.pat
I made it for the 8 faders of the BCF first page. You can easily complete the patch if you need more
Statistics: Posted by SylvainT — 26 Nov 2019, 13:30
]]>2019-11-25T17:28:43+01:002019-11-25T17:28:43+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41913#p41913Statistics: Posted by Gilsornette — 25 Nov 2019, 17:28
]]>2019-11-25T13:31:37+01:002019-11-25T13:31:37+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41911#p41911cc-rack 2019-11-24 041119.jpgbut, need to figure out correct CC array handling so this patch receives CC's in expected order. and you set sub-patch polyphony number to number of faders/knobs you want to use.
]]>2019-11-25T09:09:40+01:002019-11-25T09:09:40+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41910#p41910Statistics: Posted by nay-seven — 25 Nov 2019, 09:09
]]>2019-11-24T01:56:07+01:002019-11-24T01:56:07+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41907#p41907Statistics: Posted by x.iso — 24 Nov 2019, 01:56
]]>2019-11-23T15:09:05+01:002019-11-23T15:09:05+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41906#p41906or something else, and if I move a fader of my BCF the corresponding controller is automatically mapped to the midi remote of the output. In other words is it possible to have access, by patching, to the menu "remote assign" of a rack. I'm wondernig if it's clearer than before...
Statistics: Posted by Gilsornette — 23 Nov 2019, 15:09
Statistics: Posted by nay-seven — 22 Nov 2019, 22:17
]]>2019-11-22T14:23:28+01:002019-11-22T14:23:28+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41903#p41903Statistics: Posted by Gilsornette — 22 Nov 2019, 14:23
]]>2019-11-22T09:28:37+01:002019-11-22T09:28:37+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41899#p41899usine rack settings will do the job ?
Statistics: Posted by nay-seven — 22 Nov 2019, 09:28
]]>2019-11-21T13:28:23+01:002019-11-21T13:28:23+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41897#p41897 Is there a way to assign, in a patch, a midi remote to a rack output? Via a message or a particular module? Thank you
Statistics: Posted by Gilsornette — 21 Nov 2019, 13:28
]]>BrainModularBrainModular Users Forum2019-11-26T18:25:03+01:00https://brainmodular.org/forums/app.php/feed/topic/65702019-11-26T18:25:03+01:002019-11-26T18:25:03+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41918#p41918Statistics: Posted by Gilsornette — 26 Nov 2019, 18:25
]]>2019-11-26T13:30:04+01:002019-11-26T13:30:04+01:00https://brainmodular.org/forums/viewtopic.php?t=6570&p=41917#p41917Here's a small patch for an automatic remote with the BCF You can put it in a device.
