ArrayArrayArrayArray
BrainModularBrainModular Users Forum2007-11-28T20:01:32+01:00https://brainmodular.org/forums/app.php/feed/topic/6562007-11-28T20:01:32+01:002007-11-28T20:01:32+01:00https://brainmodular.org/forums/viewtopic.php?t=656&p=3319#p3319Statistics: Posted by senso — 28 Nov 2007, 20:01
and it is a good way to use all my joystik buttons. I need a little bit programation with Midi Filter and Logical Math Module but it works fine.
Good evening.
Statistics: Posted by cmodica — 28 Nov 2007, 18:31
]]>2007-11-26T20:04:34+01:002007-11-26T20:04:34+01:00https://brainmodular.org/forums/viewtopic.php?t=656&p=3276#p3276It seems strange but I'm not a joystick expert and actually, I don't know how to access to the 330° controllers with window. (I use a too basic library) Be patient, the improvement is in my 'do-do' list.
You can transform joysticks value to CC with the 'create Midi msg' module.
]]>2007-11-26T19:19:18+01:002007-11-26T19:19:18+01:00https://brainmodular.org/forums/viewtopic.php?t=656&p=3275#p3275 1 - It is impossible to use more than one Joystick module. If i put a second joystick Module on an other track it doesn't work and i have the message "Error : Enebled to open Joystick" ?
So i can use "send Bus" and "get bus" but ...
2 - On my very cheap Joystick i have more than 4 buttons and two 360° controller wich can control four axes. How can i use all of them ?
And a last question : Is it possible to receive Midi CC from my Joystik in usine ?
Statistics: Posted by cmodica — 26 Nov 2007, 19:19
]]>BrainModularBrainModular Users Forum2007-11-28T20:01:32+01:00https://brainmodular.org/forums/app.php/feed/topic/6562007-11-28T20:01:32+01:002007-11-28T20:01:32+01:00https://brainmodular.org/forums/viewtopic.php?t=656&p=3319#p3319Statistics: Posted by senso — 28 Nov 2007, 20:01
]]>2007-11-28T18:31:58+01:002007-11-28T18:31:58+01:00https://brainmodular.org/forums/viewtopic.php?t=656&p=3315#p3315 But i find this donationware plugin (http://pagesperso-orange.fr/silicon_silicium/index.html)
Good evening.
