ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2007-11-28T23:13:51+01:00https://brainmodular.org/forums/app.php/feed/topic/6542007-11-28T23:13:51+01:002007-11-28T23:13:51+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3329#p3329Statistics: Posted by jean-mi — 28 Nov 2007, 23:13
2007-11-28T17:53:30+01:002007-11-28T17:53:30+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3310#p3310Statistics: Posted by Newbie Brad — 28 Nov 2007, 17:53
]]>2007-11-25T13:57:42+01:002007-11-25T13:57:42+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3269#p3269You only need it if you use VstShell plugs like Waves plugs. Note that for VstShell plugs you can fine an utility call Shell2Vst (search it with google) which converts Shells into separates Vst's. Very useful.....
]]>2007-11-25T11:26:39+01:002007-11-25T11:26:39+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3268#p3268Statistics: Posted by Golcondio — 25 Nov 2007, 11:26
]]>2007-11-25T10:08:23+01:002007-11-25T10:08:23+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3267#p3267 1) normal [allow deep scan] disabled: test shortly. In that mode there is no reason to crash Usine because it's only a simple file name scan. The Only cause of crash is a bad hard disk or bad windows file system.
2) deep [allow deep scan] enabled: Usine try to open each VST to extract characteristics (number of in, out, etc.). Usine can crash if a VST is bad. But if you restart, Usine continue the scan process and ignore the bat VST. In that case You'll probably have to restart several times Usine until the entire scan is achieved.
]]>2007-11-25T08:58:11+01:002007-11-25T08:58:11+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3266#p3266It assigns an "invalid" state to a plugin that, for one reason or the other, has given problems: once so flagged, it will be skipped during VST scan. If you reset the "invalid" flag to 0, the only thing that will happen is that Usine will retry scanning it, and crash...
Statistics: Posted by Golcondio — 25 Nov 2007, 08:58
]]>2007-11-25T02:51:28+01:002007-11-25T02:51:28+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3265#p3265 found the .dll for the VST and if you have INVALID=1, try with 0
hope it help
Statistics: Posted by martignasse — 25 Nov 2007, 02:51
]]>2007-11-24T11:56:19+01:002007-11-24T11:56:19+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3264#p3264Statistics: Posted by Golcondio — 24 Nov 2007, 11:56
]]>2007-11-24T11:01:34+01:002007-11-24T11:01:34+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3263#p3263Statistics: Posted by senso — 24 Nov 2007, 11:01
]]>2007-11-24T10:46:59+01:002007-11-24T10:46:59+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3262#p3262Statistics: Posted by senso — 24 Nov 2007, 10:46
]]>2007-11-24T10:04:43+01:002007-11-24T10:04:43+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3261#p32611) I managed to run the SimulAnalog Guitar Suite, which is good; it doesn't sound very good, which is bad. 2) Frettedsynth Helian Bass is quite good, and works well. 3) IK Multimedia Ampeg SVX works very well. 4) Freeamp 2 works like a charm, and is surprisingly good! But if I save and reload a patch/workspace containing it, Usine crashes to desktop... 5) I tried IK Multimedia Amplitube 2.0, and while the first time it loaded without problems, when I activated the patch it sent CPU usage to 100% (under Cubase I can activate 2 instances, with different presets, without problems) and I had to manually close usine with the task manager... Since then, if it is present in the VST folder and I force Usine to scan it, I get a nice crash to desktop...
So I'm stuck with no convincing guitar amp simulation: any advice/comment/miracle?
Statistics: Posted by Golcondio — 24 Nov 2007, 10:04
]]>BrainModularBrainModular Users Forum2007-11-28T23:13:51+01:00https://brainmodular.org/forums/app.php/feed/topic/6542007-11-28T23:13:51+01:002007-11-28T23:13:51+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3329#p3329Statistics: Posted by jean-mi — 28 Nov 2007, 23:13
]]>2007-11-28T17:53:30+01:002007-11-28T17:53:30+01:00https://brainmodular.org/forums/viewtopic.php?t=654&p=3310#p3310Statistics: Posted by Newbie Brad — 28 Nov 2007, 17:53
hope it help
