ArrayArrayArrayArray
BrainModularBrainModular Users Forum2006-05-09T11:14:45+01:00https://brainmodular.org/forums/app.php/feed/topic/652006-05-09T11:14:45+01:002006-05-09T11:14:45+01:00https://brainmodular.org/forums/viewtopic.php?t=65&p=226#p226 The problem is that in some VST (ie: reaktor again) the parameter list depends on the preset (ensemble in reaktor). So you should modify the check list on each preset...
]]>2006-05-09T08:07:20+01:002006-05-09T08:07:20+01:00https://brainmodular.org/forums/viewtopic.php?t=65&p=222#p222Statistics: Posted by jean-marc duchenne — 09 May 2006, 09:07
2006-05-08T14:49:33+01:002006-05-08T14:49:33+01:00https://brainmodular.org/forums/viewtopic.php?t=65&p=212#p212Some "reserved" or "hiden" vst parameters give access to very interesting functions witch does appears in the basic gui. Some time I use them to make unusual effects. So what to do?
]]>2006-05-08T13:34:24+01:002006-05-08T13:34:24+01:00https://brainmodular.org/forums/viewtopic.php?t=65&p=208#p208 The direct inputs / outputs of VST parameters on the module is a VERY good idea and very powerful, but some plugins can show a huge number of useless parameters.
The question : could it be possible to give the user the possibility to select what parameters he wants to show or not ? Also, some hosts hide automatically the parameters if their name is "unused" or "hidden", "reserved" or "n/a" for example. It would be pratical to do something like this.
]]>BrainModularBrainModular Users Forum2006-05-09T11:14:45+01:00https://brainmodular.org/forums/app.php/feed/topic/652006-05-09T11:14:45+01:002006-05-09T11:14:45+01:00https://brainmodular.org/forums/viewtopic.php?t=65&p=226#p226 The problem is that in some VST (ie: reaktor again) the parameter list depends on the preset (ensemble in reaktor). So you should modify the check list on each preset...
]]>2006-05-08T14:49:33+01:002006-05-08T14:49:33+01:00https://brainmodular.org/forums/viewtopic.php?t=65&p=212#p212Some "reserved" or "hiden" vst parameters give access to very interesting functions witch does appears in the basic gui. Some time I use them to make unusual effects. So what to do?
