ArrayArrayArray BrainModular BrainModular Users Forum 2019-07-01T11:48:24+01:00 https://brainmodular.org/forums/app.php/feed/topic/6484 2019-07-01T11:48:24+01:00 2019-07-01T11:48:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=6484&p=41483#p41483 <![CDATA[Can't find C++ source code for included modules...]]>
Thank you very much, that helps quite a bit.
Statistics: Posted by lytz1 — 01 Jul 2019, 12:48
2019-07-01T09:22:15+01:00 2019-07-01T09:22:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=6484&p=41481#p41481 <![CDATA[Can't find C++ source code for included modules...]]>
But if you want to see what there is, you have to download the SDK, and you will find some modules and their code in:
Sensomusic Usine SDK HH3-7.01.006modules
and
Sensomusic Usine SDK HH3-7.01.006examples
For example, in the modulesReverb directory you find:
23/01/2019 14:13 <DIR> .
23/01/2019 14:13 <DIR> ..
23/01/2019 14:13 <DIR> .vs
23/05/2000 19:45 515 allpass.cpp
23/05/2000 21:51 837 allpass.hpp
23/05/2000 19:45 634 comb.cpp
23/05/2000 21:51 971 comb.hpp
23/05/2000 21:51 367 denormals.h
23/01/2019 14:13 <DIR> Resources
17/01/2018 19:35 20,517 Reverb.cpp
06/03/2015 22:03 6,925 Reverb.h
08/03/2017 12:40 1,293 Reverb.sln
27/06/2013 19:35 2,111 Reverb.user
17/01/2018 18:51 14,254 Reverb.vcxproj
01/09/2013 19:06 1,266 Reverb.vcxproj.fi
14/10/2013 19:57 1,099 Reverb.vcxproj.us
28/08/2013 10:34 2,125 tuning.h
The sln and vcxproj files are for Visual Studio.
Note:
It has never been clear what versions of modules are in the directories.
For example, I compiled modulesPluginWrapper-juce_5 v2, but it is not the version included in Usine,
which has extra buttons on the plugin windows.
That's as much as I know !
Simon.
Statistics: Posted by sm_jamieson — 01 Jul 2019, 10:22
2019-06-30T23:13:54+01:00 2019-06-30T23:13:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=6484&p=41480#p41480 <![CDATA[Can't find C++ source code for included modules...]]>
I am looking for the C++ source of the included modules.
Somehow I can't find anything. They should be available somewhere, no?
Any hint?
tL.
Statistics: Posted by lytz1 — 01 Jul 2019, 00:13
and
Note:
Simon.
Any hint?
tL.
