ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-01-15T21:37:40+01:00 https://brainmodular.org/forums/app.php/feed/topic/648 2008-01-15T21:37:40+01:00 2008-01-15T21:37:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3620#p3620 <![CDATA[Solo/mute patch]]> thats why Usine is 20-30% faster
Statistics: Posted by senso — 15 Jan 2008, 21:37
2008-01-15T21:36:27+01:00 2008-01-15T21:36:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3619#p3619 <![CDATA[Solo/mute patch]]> Statistics: Posted by bsork — 15 Jan 2008, 21:36
2008-01-15T18:47:50+01:00 2008-01-15T18:47:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3618#p3618 <![CDATA[Solo/mute patch]]> In the new version of usine, the multiple var module is calculated only if it's input as changed. That why your patch doesn't work any more.
Statistics: Posted by senso — 15 Jan 2008, 18:47
2008-01-15T15:14:06+01:00 2008-01-15T15:14:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3617#p3617 <![CDATA[Solo/mute patch]]>
However, I couldn't resist to rethink a way of using modules without creating an over-complex patch when the number of involved channels increases. I also have put an example up in the add-ons; it uses Pass/Stop Event Flow modules and a single A>B. Within a reasonable amount of channels (up to 20? 30?), I guess this is better than using a script, at least CPU-wise.
Statistics: Posted by bsork — 15 Jan 2008, 15:14
2008-01-15T13:54:10+01:00 2008-01-15T13:54:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3613#p3613 <![CDATA[Solo/mute patch]]>
i'll give it a look - and possibly return to using a script :)
antwan
Statistics: Posted by antwan — 15 Jan 2008, 13:54
2008-01-15T13:14:21+01:00 2008-01-15T13:14:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3610#p3610 <![CDATA[Solo/mute patch]]>
If the previous patch was working it was only by "chance". I mean that the order of calculation was made for the patch to work but wasn't valid in the general case.
the problem is more complex than appears!
[mute1] is on when:
[solo2]=on OR [solo3]=on but only when [solo1]=off
in math domain it looks like:
mute1 = (solo2 OR solo3) and (not solo1)
mute2 = (solo1 OR solo3) and (not solo2)
mute3 = (solo1 OR solo2) and (not solo3)
so on the patch you only need OR, AND, NOT modules.
I've just posted an example in the add-ons section.
You see that the complexity grow with the number of buttons, and can be rapidly a nightmare.
So the script is a good candidate, with a constant to define the number of solo buttons (3,5 or 1764 !)
Statistics: Posted by senso — 15 Jan 2008, 13:14
2008-01-15T10:37:03+01:00 2008-01-15T10:37:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3602#p3602 <![CDATA[Solo/mute patch]]> Statistics: Posted by bsork — 15 Jan 2008, 10:37
2008-01-15T10:11:45+01:00 2008-01-15T10:11:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3601#p3601 <![CDATA[Solo/mute patch]]> I'll take a look
contact @ sensomusic.com
Statistics: Posted by senso — 15 Jan 2008, 10:11
2008-01-15T09:57:11+01:00 2008-01-15T09:57:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3600#p3600 <![CDATA[Solo/mute patch]]>
Any comments, Olivier? Something wrong with copying several modules in one go, maybe?
Statistics: Posted by bsork — 15 Jan 2008, 09:57
2008-01-14T19:37:55+01:00 2008-01-14T19:37:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3591#p3591 <![CDATA[Solo/mute patch]]>
Strange, i opened this patch (made with the Multiple Vars) with the new version of Usine, hadn't used it for a while. And it seems it doesn't work now. When a Solo is pressed, it also Mutes the channel that was soloed. i.e. it mutes all channels regardless.
Any thoughts on what has changed?
antwan
Statistics: Posted by antwan — 14 Jan 2008, 19:37
2007-11-22T14:51:32+01:00 2007-11-22T14:51:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3241#p3241 <![CDATA[Solo/mute patch]]>
fascinating.
it's still hard sometimes to figure out when to go for scripting and when to stick to module-building.
antwan
In this case, I was "lucky" since the logic here can be expressed in 3 steps which fit the MultipleVar module perfect:
1) No solo? Don't mute
2) Solo? Mute, unless...
3) ...the corresponding solo button is on.
...and adding mute switches to MultipleVar.in1 works very well! Actually, I don't think all DAWs has that functionality - on some a muted channel will be unmuted after a solo.
Statistics: Posted by bsork — 22 Nov 2007, 14:51
2007-11-22T12:28:20+01:00 2007-11-22T12:28:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3239#p3239 <![CDATA[Solo/mute patch]]> I think it works.
Statistics: Posted by moody33 — 22 Nov 2007, 12:28
2007-11-22T11:22:28+01:00 2007-11-22T11:22:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3238#p3238 <![CDATA[Solo/mute patch]]> Statistics: Posted by moody33 — 22 Nov 2007, 11:22
2007-11-22T11:10:17+01:00 2007-11-22T11:10:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3237#p3237 <![CDATA[Solo/mute patch]]>
i'm looking into improving this script further so that:
- if some channel was muted before solo is activated, it will return to be muted after the solo is disactivated
- also so that several solos can be active at the same time (as moody33 mentioned)
It's exactly what I want. Propellerhead Reason Mixer work like this if I remember.
Thanks everybody , I will try Bsork last suggestion.
Statistics: Posted by moody33 — 22 Nov 2007, 11:10
2007-11-22T11:02:05+01:00 2007-11-22T11:02:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3235#p3235 <![CDATA[Solo/mute patch]]> it's still hard sometimes to figure out when to go for scripting and when to stick to module-building.
antwan
Statistics: Posted by antwan — 22 Nov 2007, 11:02
2007-11-22T10:31:31+01:00 2007-11-22T10:31:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3233#p3233 <![CDATA[Solo/mute patch]]>
However, the script is a bit heavy on the CPU, so I've made the same functionality with modules:
First create a solo Switch, a mute Switch and a MultipleVar. Connect the solo Switch to MultipleVar.affect3, and the mute Switch to MultipleVar.out. Set MultipleVar.in2 = 1.
Select all three modules and copy them so that you have as many channels as you want.
Then create a A=B and a Not module. Connect all solo switches to A=B.A, and A=B.out to Not.in. Then connect A=B.out to affect1 and Not.out to affect2 on all MultipleVars. Voila - it wasn't so hard after all!
On my system the script uses around 5 times the CPU as this patch when running 8 channels.
Statistics: Posted by bsork — 22 Nov 2007, 10:31
2007-11-22T09:51:32+01:00 2007-11-22T09:51:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3232#p3232 <![CDATA[Solo/mute patch]]>
looks good.
i'll have to see how the solo/mute engines work generally in DAW-softwares but im pretty sure at least the functionalities mentioned above are valid...
i hope i'll have time today or tomorrow.
antwan
Statistics: Posted by antwan — 22 Nov 2007, 09:51
2007-11-21T21:45:22+01:00 2007-11-21T21:45:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3228#p3228 <![CDATA[Solo/mute patch]]>
CODE:
VAR pIn   &#58; ARRAY OF TParameter;VAR pOut  &#58; ARRAY OF TParameter;VAR i     &#58; integer;VAR bOn &#58; BOOLEAN;VAR tmp   &#58; ARRAY OF integer;CONST NUM_CH = 8;PROCEDURE init;BEGIN   SetArrayLength&#40;pIn, NUM_CH&#41;;   SetArrayLength&#40;pOut, NUM_CH&#41;;   SetArrayLength&#40;tmp, NUM_CH&#41;;   FOR i &#58;= 0 TO &#40;NUM_CH - 1&#41; DO BEGIN      pIn&#91;i&#93; &#58;= CreateParam&#40;'solo in'+IntToStr&#40;i+1&#41;, ptSwitch&#41;;      SetIsOutput&#40;pIn&#91;i&#93;, FALSE&#41;;   END;   FOR i &#58;= 0 TO &#40;NUM_CH - 1&#41; DO BEGIN      pOut&#91;i&#93; &#58;= CreateParam&#40;'mute out'+IntToStr&#40;i+1&#41;, ptSwitch&#41;;      SetIsInput&#40;pOut&#91;i&#93;, FALSE&#41;;   END;END;BEGIN   bOn &#58;= FALSE;   FOR i &#58;= 0 TO &#40;NUM_CH - 1&#41; DO BEGIN      tmp&#91;i&#93; &#58;= trunc&#40;GetValue&#40;pIn&#91;i&#93;&#41;&#41;;       IF &#40;tmp&#91;i&#93; = 1&#41; THEN        bOn &#58;= TRUE;   END;   IF &#40;bOn&#41; THEN BEGIN      FOR i &#58;= 0 TO &#40;NUM_CH - 1&#41; DO BEGIN         IF &#40;tmp&#91;i&#93; = 1&#41; THEN BEGIN            SetValue&#40;pOut&#91;i&#93;, 0&#41;;         END         ELSE BEGIN            SetValue&#40;pOut&#91;i&#93;, 1&#41;;         END;      END;   END   ELSE BEGIN      FOR i &#58;= 0 TO &#40;NUM_CH - 1&#41; DO         SetValue&#40;pOut&#91;i&#93;, 0&#41;;   END;END.
I think it could have been a bit more compact and efficient, but I'm tired tonight...
Statistics: Posted by bsork — 21 Nov 2007, 21:45
2007-11-21T20:23:59+01:00 2007-11-21T20:23:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3223#p3223 <![CDATA[Solo/mute patch]]>
I don't understand scripting ..so pleaseeeeee a candidate !
Statistics: Posted by moody33 — 21 Nov 2007, 20:23
2007-11-21T20:06:55+01:00 2007-11-21T20:06:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3220#p3220 <![CDATA[Solo/mute patch]]> Statistics: Posted by senso — 21 Nov 2007, 20:06
2007-11-21T19:51:21+01:00 2007-11-21T19:51:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3217#p3217 <![CDATA[Solo/mute patch]]> if someone more experienced is up for it, go right ahead!
antwan
Statistics: Posted by antwan — 21 Nov 2007, 19:51
2007-11-21T19:48:16+01:00 2007-11-21T19:48:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3216#p3216 <![CDATA[Solo/mute patch]]> The best way to create a solo switch is to make a small script!
Any candidate?
Statistics: Posted by senso — 21 Nov 2007, 19:48
2007-11-21T14:19:57+01:00 2007-11-21T14:19:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=648&p=3207#p3207 <![CDATA[Solo/mute patch]]>
thanks you.
Statistics: Posted by moody33 — 21 Nov 2007, 14:19
antwan
[mute1] is on when:
antwan
fascinating.
antwan
antwan
looks good.
antwan
CODE:
antwan
Any candidate?
thanks you.
