Create a new rack and add a rack settings module, select the rack number and use the on outlet
nay, is there a difference between on and enabled besides the outlet?
Statistics: Posted by iococoi — 14 May 2019, 14:46
]]>2019-05-14T13:40:16+01:002019-05-14T13:40:16+01:00https://brainmodular.org/forums/viewtopic.php?t=6451&p=41261#p41261Statistics: Posted by iococoi — 14 May 2019, 14:40
Statistics: Posted by iococoi — 14 May 2019, 14:36
]]>2019-05-14T13:34:56+01:002019-05-14T13:34:56+01:00https://brainmodular.org/forums/viewtopic.php?t=6451&p=41258#p41258Statistics: Posted by benjotrash — 14 May 2019, 14:34
]]>2019-05-14T13:31:19+01:002019-05-14T13:31:19+01:00https://brainmodular.org/forums/viewtopic.php?t=6451&p=41257#p41257
Statistics: Posted by iococoi — 14 May 2019, 14:31
Statistics: Posted by nay-seven — 14 May 2019, 13:42
]]>2019-05-14T10:30:19+01:002019-05-14T10:30:19+01:00https://brainmodular.org/forums/viewtopic.php?t=6451&p=41253#p41253Statistics: Posted by benjotrash — 14 May 2019, 11:30
]]>2019-05-14T08:18:52+01:002019-05-14T08:18:52+01:00https://brainmodular.org/forums/viewtopic.php?t=6451&p=41252#p41252there is an enabled outlet..you could use this..
Statistics: Posted by iococoi — 14 May 2019, 09:18
]]>2019-05-14T07:44:32+01:002019-05-14T07:44:32+01:00https://brainmodular.org/forums/viewtopic.php?t=6451&p=41251#p41251 I try to show a led in the Interface Builder when a rack is on, but in the usine rack module the on-off cannot be connected... Is there another way to do this?
Thank you very much for the help...
Benjo
Statistics: Posted by benjotrash — 14 May 2019, 08:44
Benjo
