ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2019-07-03T18:54:04+01:00https://brainmodular.org/forums/app.php/feed/topic/64452019-07-03T18:54:04+01:002019-07-03T18:54:04+01:00https://brainmodular.org/forums/viewtopic.php?t=6445&p=41484#p41484normally it's made for that.
]]>2019-05-01T21:55:39+01:002019-05-01T21:55:39+01:00https://brainmodular.org/forums/viewtopic.php?t=6445&p=41171#p41171Statistics: Posted by x.iso — 01 May 2019, 22:55
2019-05-01T20:57:16+01:002019-05-01T20:57:16+01:00https://brainmodular.org/forums/viewtopic.php?t=6445&p=41168#p41168I don't know if the on-screen keyboard is supposed to come up automatically on double-touch, but I put an icon to switch the on-screen keyboard on the taskbar so I can just select that.
Simon.
Statistics: Posted by sm_jamieson — 01 May 2019, 21:57
]]>2019-05-01T13:56:46+01:002019-05-01T13:56:46+01:00https://brainmodular.org/forums/viewtopic.php?t=6445&p=41155#p41155 There are few things that for some reason don't work with touch in HH3 - for instance the division bar for patcher (when it's not windowed) or grid is not adjustable with touch.
]]>2019-05-01T13:28:32+01:002019-05-01T13:28:32+01:00https://brainmodular.org/forums/viewtopic.php?t=6445&p=41154#p41154and therefore only using the touchscreen.
In the Settings I can change values that have a slider or combi box, etc. But there is no way to open then value entry box to enter a value (via the on-screen keyboard). Using the mouse, a double click would open the selection box. The usual equivalent of a double click on Windows is a long touch.
On Usine, a long touch on the Settings makes a large selection square appear (a Windows effect ?), but nothing else happens.
Can we have a general way in Usine for a touchscreen to do either: 1. A double click (probably the best solution) OR 2. Open the settings entry box.
Thanks, Simon.
Statistics: Posted by sm_jamieson — 01 May 2019, 14:28
]]>BrainModularBrainModular Users Forum2019-07-03T18:54:04+01:00https://brainmodular.org/forums/app.php/feed/topic/64452019-07-03T18:54:04+01:002019-07-03T18:54:04+01:00https://brainmodular.org/forums/viewtopic.php?t=6445&p=41484#p41484normally it's made for that.
]]>2019-05-01T20:57:16+01:002019-05-01T20:57:16+01:00https://brainmodular.org/forums/viewtopic.php?t=6445&p=41168#p41168I don't know if the on-screen keyboard is supposed to come up automatically on double-touch, but I put an icon to switch the on-screen keyboard on the taskbar so I can just select that.
Simon.
Thanks, Simon.
