ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2019-05-04T19:02:32+01:00 https://brainmodular.org/forums/app.php/feed/topic/6432 2019-05-04T19:02:32+01:00 2019-05-04T19:02:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=6432&p=41201#p41201 <![CDATA[Sending Program change]]>
Statistics: Posted by noise2sine — 04 May 2019, 20:02
2019-05-04T16:41:24+01:00 2019-05-04T16:41:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=6432&p=41196#p41196 <![CDATA[Sending Program change]]> patch setting module/ outlet current preset num/has changed/inlet create of your MIDI module
Statistics: Posted by nay-seven — 04 May 2019, 17:41
2019-05-04T16:04:45+01:00 2019-05-04T16:04:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=6432&p=41195#p41195 <![CDATA[Sending Program change]]>
I was wandering how can i send a program change message when recalling a preset inside a patch ?
I already have the module in my patch but i have to manually press the create button to send the message .
Thank you
Statistics: Posted by noise2sine — 04 May 2019, 17:04
2019-05-04T07:34:20+01:00 2019-05-04T07:34:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=6432&p=41186#p41186 <![CDATA[Sending Program change]]> patch setting module with a fader linked to current preset num inlet
Statistics: Posted by nay-seven — 04 May 2019, 08:34
2019-04-07T15:46:28+01:00 2019-04-07T15:46:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=6432&p=41067#p41067 <![CDATA[Sending Program change]]>
for midi patch change, use the midi create module
Statistics: Posted by oli_lab — 07 Apr 2019, 16:46
2019-04-06T17:08:44+01:00 2019-04-06T17:08:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=6432&p=41065#p41065 <![CDATA[Sending Program change]]> I’m looking for an idea for sending program change within an existing patch ? Any advice ?
Thank you
Statistics: Posted by noise2sine — 06 Apr 2019, 18:08
Thank you
Thank you
