ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2019-02-24T19:25:24+01:00https://brainmodular.org/forums/app.php/feed/topic/64022019-02-24T19:25:24+01:002019-02-24T19:25:24+01:00https://brainmodular.org/forums/viewtopic.php?t=6402&p=40900#p40900same problem here, on windows 10.
]]>2019-02-13T21:30:59+01:002019-02-13T21:30:59+01:00https://brainmodular.org/forums/viewtopic.php?t=6402&p=40885#p40885http://www.rohitab.com/apimonitor then it does ! I suppose that runs things in a slightly different environment.
Statistics: Posted by sm_jamieson — 13 Feb 2019, 21:30
]]>2019-02-13T10:43:21+01:002019-02-13T10:43:21+01:00https://brainmodular.org/forums/viewtopic.php?t=6402&p=40874#p40874I'm moving to a new laptop soon so not that worried, but it is strange. I could try "installing" the DLLs with regsvr32 to see if that works.
Simon.
Statistics: Posted by sm_jamieson — 13 Feb 2019, 10:43
Also, I tried "unblocking" the zip file before installing.
If you unpacked it in Program Files folder or any other system folder, than that's the problem most likely, since it may move executable in protected environment upon launch, but without necessary libraries or other files.
]]>2019-02-12T16:38:55+01:002019-02-12T16:38:55+01:00https://brainmodular.org/forums/viewtopic.php?t=6402&p=40862#p40862No idea for now. Normally av* files are included in the package /bin/ Try the opposite : locate and remove all the av* you can find in the C: I suspect a conflict between already installed DLL's ? try also to list all environment variables and see if you can find something suspect? https://www.askvg.com/list-of-environme ... sta-and-7/
]]>2019-02-12T16:29:29+01:002019-02-12T16:29:29+01:00https://brainmodular.org/forums/viewtopic.php?t=6402&p=40861#p40861Statistics: Posted by sm_jamieson — 12 Feb 2019, 16:29
2019-02-12T16:20:52+01:002019-02-12T16:20:52+01:00https://brainmodular.org/forums/viewtopic.php?t=6402&p=40860#p40860The Application was Unable to Start Correctly (0xc000007b) I thought windows would always look in the current directory for DLLs.
Statistics: Posted by sm_jamieson — 12 Feb 2019, 16:20
]]>2019-02-12T16:04:50+01:002019-02-12T16:04:50+01:00https://brainmodular.org/forums/viewtopic.php?t=6402&p=40859#p40859Statistics: Posted by x.iso — 12 Feb 2019, 16:04
]]>2019-02-12T15:04:59+01:002019-02-12T15:04:59+01:00https://brainmodular.org/forums/viewtopic.php?t=6402&p=40857#p40857 The program can't start because avutil-54.DLL is missing from you computer. Try reinstalling the program to fix this problem.
The DLL is in the bin directory and even it I run Usine.exe in there rather than the startup executable, the same error occurs
Simon.
Statistics: Posted by sm_jamieson — 12 Feb 2019, 15:04
improvements - Usine can now open corrupted wave files. - Better Oscillator Wave-table module.
bugs
- Zoom should not be allowed in the browser panel. - Tempo fader not saved in local-syncro module. - Grid_section module: captions output truncated when grid is zoomed out. - Racks/patches on the grid can stop at the end of sections. - MIDI sampler module doesn't work properly in reverse mode.
[large]3.0.187[/large]
improvements - Mouse event on the piano-roll module.
bugs - The path module is saved with the workspace. - MIDI-sampler plays only in mono mode. - Load-Patch can load patches twice. - Load-Rack can load Racks twice.
Statistics: Posted by nay-seven — 09 Feb 2019, 22:43
]]>BrainModularBrainModular Users Forum2019-02-24T19:25:24+01:00https://brainmodular.org/forums/app.php/feed/topic/64022019-02-24T19:25:24+01:002019-02-24T19:25:24+01:00https://brainmodular.org/forums/viewtopic.php?t=6402&p=40900#p40900same problem here, on windows 10.
Simon.
]]>2019-02-12T16:20:52+01:002019-02-12T16:20:52+01:00https://brainmodular.org/forums/viewtopic.php?t=6402&p=40860#p40860The Application was Unable to Start Correctly (0xc000007b) I thought windows would always look in the current directory for DLLs.
Simon.
bugs
