ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2019-03-16T12:35:55+01:00https://brainmodular.org/forums/app.php/feed/topic/64012019-03-16T12:35:55+01:002019-03-16T12:35:55+01:00https://brainmodular.org/forums/viewtopic.php?t=6401&p=40976#p40976Statistics: Posted by x.iso — 16 Mar 2019, 12:35
2019-03-16T12:11:16+01:002019-03-16T12:11:16+01:00https://brainmodular.org/forums/viewtopic.php?t=6401&p=40975#p40975Statistics: Posted by senso — 16 Mar 2019, 12:11
]]>2019-03-15T18:41:09+01:002019-03-15T18:41:09+01:00https://brainmodular.org/forums/viewtopic.php?t=6401&p=40970#p40970What about other module I've mentioned, is it possible to make?
]]>2019-03-15T13:16:56+01:002019-03-15T13:16:56+01:00https://brainmodular.org/forums/viewtopic.php?t=6401&p=40965#p40965I'm not sure I will be able to do that safely in CPU terms. I'll see in HH4
]]>2019-02-08T14:06:47+01:002019-02-08T14:06:47+01:00https://brainmodular.org/forums/viewtopic.php?t=6401&p=40834#p40834If it's hard to implement for some reason, then maybe it's time to make simplified Piano roll UI module, kind of like matrix module or step sequencer, with limited notes (perhaps integrating scales would be helpful as well) and steps (lenght) range, but with ability to edit it directly and also manipulate it's data from arrays. So things like wobbling notes could be possible, for example that would make notes play slightly off-grid and the offset would be different on each loop cycle. I think there's lots of other uses as well.
]]>BrainModularBrainModular Users Forum2019-03-16T12:35:55+01:00https://brainmodular.org/forums/app.php/feed/topic/64012019-03-16T12:35:55+01:002019-03-16T12:35:55+01:00https://brainmodular.org/forums/viewtopic.php?t=6401&p=40976#p40976Statistics: Posted by x.iso — 16 Mar 2019, 12:35
]]>2019-03-16T12:11:16+01:002019-03-16T12:11:16+01:00https://brainmodular.org/forums/viewtopic.php?t=6401&p=40975#p40975Statistics: Posted by senso — 16 Mar 2019, 12:11
