ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2019-01-30T13:16:48+01:00 https://brainmodular.org/forums/app.php/feed/topic/6393 2019-01-30T13:16:48+01:00 2019-01-30T13:16:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=6393&p=40796#p40796 <![CDATA[Having trouble with [sound files folder]]]> support@sensomusic.org please ?
Statistics: Posted by nay-seven — 30 Jan 2019, 13:16
2019-01-30T11:47:33+01:00 2019-01-30T11:47:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=6393&p=40795#p40795 <![CDATA[Having trouble with [sound files folder]]]> Helped with a lot of problems in my case. No idea why, but it did.
Some other files (though very few) also showed this problem no matter what.
Sometimes it helps when you just duplicate them and delete the originals.
It seems that depending from which DAW I export, I get more or less/none of these errors.
Maybe something is printed into these WAVs that HH doesn't like too much... ;)
Also I had this error popping up far more often on OSX than on Windows.
Best,
tL.
Statistics: Posted by lytz1 — 30 Jan 2019, 11:47
2019-01-28T20:20:39+01:00 2019-01-28T20:20:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=6393&p=40790#p40790 <![CDATA[Having trouble with [sound files folder]]]> Statistics: Posted by oli_lab — 28 Jan 2019, 20:20
2019-01-28T17:20:28+01:00 2019-01-28T17:20:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=6393&p=40789#p40789 <![CDATA[Having trouble with [sound files folder]]]> Statistics: Posted by Lib — 28 Jan 2019, 17:20
2019-01-28T01:07:03+01:00 2019-01-28T01:07:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=6393&p=40788#p40788 <![CDATA[Having trouble with [sound files folder]]]>
Thanks?
Statistics: Posted by nateflanigan — 28 Jan 2019, 01:07
2019-01-27T19:43:24+01:00 2019-01-27T19:43:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=6393&p=40785#p40785 <![CDATA[Having trouble with [sound files folder]]]>
Any idea how to fix this? And what do the brackets around [sound files folder] mean?
Thanks!
Statistics: Posted by nateflanigan — 27 Jan 2019, 19:43
Best,
tL.
Thanks?
Thanks!
