ArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2020-01-16T12:53:27+01:00 https://brainmodular.org/forums/app.php/feed/topic/6378 2020-01-16T12:53:27+01:00 2020-01-16T12:53:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=6378&p=42100#p42100 <![CDATA[Re: more control of VST window]]> Statistics: Posted by SylvainT — 16 Jan 2020, 12:53
2020-01-14T22:23:53+01:00 2020-01-14T22:23:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=6378&p=42090#p42090 <![CDATA[Re: more control of VST window]]> There may be some Juce functions that can do it.
Statistics: Posted by sm_jamieson — 14 Jan 2020, 22:23
2020-01-13T00:59:39+01:00 2020-01-13T00:59:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=6378&p=42070#p42070 <![CDATA[Re: more control of VST window]]> Statistics: Posted by woodslanding — 13 Jan 2020, 00:59
2020-01-12T16:29:34+01:00 2020-01-12T16:29:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=6378&p=42065#p42065 <![CDATA[Re: more control of VST window]]> Statistics: Posted by senso — 12 Jan 2020, 16:29
2020-01-10T11:54:54+01:00 2020-01-10T11:54:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=6378&p=42045#p42045 <![CDATA[Re: more control of VST window]]> So you could produce a patch to do this. You'd have to use buses if you plugins are in different patches.
The other point about hiding the VST windows is that you can
1. Ask the VST to open its GUI - which can take some time
2. Hide the VST GUI, but leave it open - so when it is un-hidden it appears to have opened instantly.
The "visible" toggle or switch on the plugin module is I presume asking the VST to open/close it's GUI.
The possible down-side to leaving the GUI open but hidden, is that the VST could be performing some GUI actions
that it would not if the GUI was closed. But I would expect the OS window handling to stop most of that.
But it would be nice to have the option.
Statistics: Posted by sm_jamieson — 10 Jan 2020, 11:54
2020-01-09T22:43:52+01:00 2020-01-09T22:43:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=6378&p=42032#p42032 <![CDATA[Re: more control of VST window]]> Statistics: Posted by woodslanding — 09 Jan 2020, 22:43
2019-01-17T20:18:31+01:00 2019-01-17T20:18:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=6378&p=40724#p40724 <![CDATA[more control of VST window]]> But I'll add 2 options on the vst module
- set as a forward (stay on top) window or backward
- a bring to front input
I'll try to do that.
Statistics: Posted by senso — 17 Jan 2019, 20:18
2019-01-17T12:57:00+01:00 2019-01-17T12:57:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=6378&p=40717#p40717 <![CDATA[more control of VST window]]> the Usine window and get in the way (especially on a laptop).
It would be useful if the VST window could be open, but "hidden", moved under the Usine window, or shifted off the
side of the screen under the control of Usine so that you can select the open window to use. This window would then
be put in the middle of the screen, or at a user controlled location.
Simon.
Statistics: Posted by sm_jamieson — 17 Jan 2019, 12:57
Simon.
