ArrayArrayArray BrainModular BrainModular Users Forum 2019-01-09T21:36:59+01:00 https://brainmodular.org/forums/app.php/feed/topic/6374 2019-01-09T21:36:59+01:00 2019-01-09T21:36:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=6374&p=40687#p40687 <![CDATA['Get number of current voices' from midi input notes]]> so can use =144 to create an array that will look here like 1,1,1. a sum array out of that give you 3 notes on currently received. (144 beeing not on code)
if say messages receive where 144,128,144, would return you 2.
if need to track over time which note have been on/off, that quite more complex. not sur a script exist currently..
Statistics: Posted by 23fx23 — 09 Jan 2019, 21:36
2019-01-09T21:28:07+01:00 2019-01-09T21:28:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=6374&p=40686#p40686 <![CDATA['Get number of current voices' from midi input notes]]>
Midi In (code1) -> Array Queue (Gets reset on Note Off) -> Get Size Arr = Actual number of voices played right now.
It's a bit shaky and not ideal but might work for now.
If anyone has a better idea, please let me know...
Statistics: Posted by lytz1 — 09 Jan 2019, 21:28
2019-01-09T21:09:34+01:00 2019-01-09T21:09:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=6374&p=40684#p40684 <![CDATA['Get number of current voices' from midi input notes]]>
I am sorry, have another one here where I could use some help.
There might be already a script or module for that outthere
or another workadound. If so please point me there.
On midi input: I need to get number of voices that are played
as a simple integer data number, so when a three note chord is played,
I get a 3 as result. I need that number to dynamically set the size of several arrays.
I couldn't find anything yet that does that but this seems to be so basic that
I might have overlooked something.
Any ideas?
tL.
Statistics: Posted by lytz1 — 09 Jan 2019, 21:09
Any ideas?
tL.
