Have you tried the Interface Control/Syncro/Local Synchronization module?
I'm at work now, so I haven't done much testing, but I checked how one of the HeliosII LFOs reacted, and it followed the local tempo as it should. Don't know about time signature, though, and I haven't got any means to try it. Does the VST clock really contain info about that?
On the other hand, I also tried the Analog Delay, and that one didn't follow the tempo at all - neither global nor local. I'm not sure, but I think I've used this one with tempo sync before without problems.
No, but I will experiment.
There's some esoteric time-send info from hosts that VSTs receive which I've learned about, oddly enough, doing bug reports for beta testing plug-ins. Not all hosts send this info, but it can't be all that complex. I guess I'll have to rifle around in the VST SDK and see what the exact message parameters are.
Statistics: Posted by runagate — 15 Nov 2007, 23:18
]]>2007-11-15T07:35:25+01:002007-11-15T07:35:25+01:00https://brainmodular.org/forums/viewtopic.php?t=635&p=3138#p3138 I'm at work now, so I haven't done much testing, but I checked how one of the HeliosII LFOs reacted, and it followed the local tempo as it should. Don't know about time signature, though, and I haven't got any means to try it. Does the VST clock really contain info about that?
]]>2007-11-14T23:49:38+01:002007-11-14T23:49:38+01:00https://brainmodular.org/forums/viewtopic.php?t=635&p=3137#p3137Statistics: Posted by runagate — 14 Nov 2007, 23:49
