ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2018-12-06T10:50:01+01:00 https://brainmodular.org/forums/app.php/feed/topic/6334 2018-12-06T10:50:01+01:00 2018-12-06T10:50:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=6334&p=40511#p40511 <![CDATA["Rec mode " in Echoplexx]]>
Yes, it seems to works alright ! Thanks.
Still working on it right now.
I'll will let you know later on when it works well.
I have to look for bugs now.
Best
Christophe
Statistics: Posted by Christophe Rault — 06 Dec 2018, 10:50
2018-12-05T09:26:25+01:00 2018-12-05T09:26:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=6334&p=40505#p40505 <![CDATA["Rec mode " in Echoplexx]]> Sylvain
Statistics: Posted by SylvainT — 05 Dec 2018, 09:26
2018-12-04T21:36:34+01:00 2018-12-04T21:36:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=6334&p=40504#p40504 <![CDATA["Rec mode " in Echoplexx]]>
Everything is going well with the patch.
Thanks a lot !
I've made it with 10 loopers and four audio output going in 2 surround panner.
I've also implemented a fixed duration, chosen prior to recording (5 sec each layers for example). So we have to press a button only once (useful in live situation where no tempo is needed).
The only problem so far is a digital clic happening on each looping point. I'm trying to find a solution. But do you think of something that could help ?
here is the rack as it is now.
http://www.sensomusic.org/forums/upload ... 20GUI.rack
Thanks again to all.
Best
C.
Statistics: Posted by Christophe Rault — 04 Dec 2018, 21:36
2018-12-01T10:03:10+01:00 2018-12-01T10:03:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=6334&p=40498#p40498 <![CDATA["Rec mode " in Echoplexx]]> I'll have a try. I'll tell you how it goes.
Best
Christophe
Statistics: Posted by Christophe Rault — 01 Dec 2018, 10:03
2018-11-30T21:48:33+01:00 2018-11-30T21:48:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=6334&p=40497#p40497 <![CDATA["Rec mode " in Echoplexx]]>
What you mean is :
1st trigger = rec base
2nd trigger = stop base rec and start layer 1 rec (after the lenght of base, stop layer 1 rec and start rec for layer 2, after the lenght of base, stop layer 2 rec and start rec for layer 3, ...)
What I would do is build a brand new patch with
5 samplers
a rec switch (master)
from your rec switch :
0 to 1 - set on - rec base
1 to 0 - set off - rec base
/ set on - rec layer 2
/ start - count ms of the lenght of the base
finished trigger - set off - rec layer 2
/ set on - rec layer 3
finished trigger - set off - rec layer 3
/ set on - rec layer 4
something like this
hope it helps ...
Statistics: Posted by grego mondo — 30 Nov 2018, 21:48
2018-11-30T12:34:27+01:00 2018-11-30T12:34:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=6334&p=40494#p40494 <![CDATA["Rec mode " in Echoplexx]]>
I'm actually building a loop pedal for a dance performer, based on Echoplexx.
Each layer goes into a surround panner SIMPLE.
I'm using 4 speakers, so each layer turns around with its own speed, or randomly.
Everything's ok so far.
I only need to be able to toggle between 2 behaviors for the REC button.
The first one (the one that works actually):
Press REC to record the BASE layer.
Press REC to stop it.
Then press REC to start the layer 1
Then press REC to stop layer 1,
So on.......
The second behavior I need to do is :
-Press REC to record the Base layer.
-Then press REC to stop the BASE Layer AND start the First Layer at the same time.
-After that, no need to press again the REC button for the other layer. Every layer is recording one after the other according to the BASE layer's duration.
How could I achieve that ?
Here is the link for the rack as it is now.
http://www.sensomusic.org/forums/upload ... akers.rack
thanks a lot for your help.
Best
Christophe Rault
Statistics: Posted by Christophe Rault — 30 Nov 2018, 12:34
Best
Christophe
Thanks a lot !
Best
C.
Best
Christophe
What you mean is :
5 samplers
something like this
hope it helps ...
So on.......
Best
Christophe Rault
