ArrayArrayArrayArrayArrayArrayArrayArrayArray
as you can see, one with no compression performs better even at higher resolution than one compressed at less resolution. both are mov files, that doesn't really matter, same with avi.Video: JPEG 1280x720 30fps 60783kbps [V: Apple Alias Data Handler [eng] (mjpeg, yuvj422p, 1280x720, 60783 kb/s)]
Audio: PCM 44100Hz stereo 1411kbps [A: Apple Alias Data Handler [eng] (pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s)]
as you can see it's mostly the same as the worst one, but bitrate is considerably lower and framerate is also less. so I guess if you're going to have compressed video, it's better if it's more compressed? I don't know if that's how it works.Video: MPEG4 Video (H264) 1024x576 24fps 7538kbps [V: DataHandler [eng] (h264 constrained baseline L3.2, yuv420p, 1024x576, 7538 kb/s)]
Audio: AAC 44100Hz stereo 152kbps [A: DataHandler [eng] (aac lc, 44100 Hz, stereo, 152 kb/s)]
Video: DivX 6 1280x720 25fps 2991kbps [V: mpeg4 simple profile, yuv420p, 1280x720, 2991 kb/s]
Audio: PCM 44100Hz stereo 1411kbps [A: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s]
Statistics: Posted by x.iso — 27 Nov 2018, 15:42
Statistics: Posted by joffo78 — 26 Nov 2018, 17:18
Statistics: Posted by TimTight — 20 Nov 2018, 14:12
Statistics: Posted by joffo78 — 15 Nov 2018, 19:23
