ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2020-04-26T12:05:17+01:00 https://brainmodular.org/forums/app.php/feed/topic/6305 2020-04-26T12:05:17+01:00 2020-04-26T12:05:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=42462#p42462 <![CDATA[Re: NOundo 0.343 release]]> simply download the zip file in the first post and load the .wkp from Usine ?
Statistics: Posted by nay-seven — 26 Apr 2020, 13:05
2020-04-26T11:49:29+01:00 2020-04-26T11:49:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=42461#p42461 <![CDATA[Re: NOundo 0.343 release]]>
i should be a Gold Member for try it ?
Statistics: Posted by amok — 26 Apr 2020, 12:49
2019-01-25T18:56:56+01:00 2019-01-25T18:56:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40779#p40779 <![CDATA[NOundo 0.343 release]]> the first 4 row of the matrix answer correctly when you press a pad ON, but no feedback when you switch Off, normal cause the color code of the APC is different
I'm afraid Noundo is made for launchpad, or it will need some work to also answer to an APC
Statistics: Posted by nay-seven — 25 Jan 2019, 18:56
2019-01-25T16:59:38+01:00 2019-01-25T16:59:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40778#p40778 <![CDATA[NOundo 0.343 release]]> Statistics: Posted by joffo78 — 25 Jan 2019, 16:59
2019-01-25T15:09:40+01:00 2019-01-25T15:09:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40775#p40775 <![CDATA[NOundo 0.343 release]]> There's 2 scripts in the addon named launchpad to APC and APC to launchpad , you'll need to insert them in the midi in / out device to correct this i suppose ?
Joffo can you confirm ?
Statistics: Posted by nay-seven — 25 Jan 2019, 15:09
2019-01-22T20:07:04+01:00 2019-01-22T20:07:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40763#p40763 <![CDATA[NOundo 0.343 release]]> Statistics: Posted by gwennaelle — 22 Jan 2019, 20:07
2018-11-29T20:13:36+01:00 2018-11-29T20:13:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40485#p40485 <![CDATA[NOundo 0.343 release]]> Statistics: Posted by joffo78 — 29 Nov 2018, 20:13
2018-11-29T19:56:01+01:00 2018-11-29T19:56:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40484#p40484 <![CDATA[NOundo 0.343 release]]> Verifying the connection, I notice a strange behavior when in the launchpad I click on a pad :
- 1st clic : the pad on Ipad and the one on Noundo are red,
- 2nd clic : the pad on Ipad is black and the one in Noundo is red,
- 3d clic : the pad on Ipad is red and the one in Noundo is black,
- 4d clic : the pad on Ipad and the one in Noundo are black.
How could we control controllers behavior?
How to activate the input tracks?
Questions at beginning... I will spend time on it especially to play with the launchpad.
Thanks for this proposition !
Statistics: Posted by gwennaelle — 29 Nov 2018, 19:56
2018-11-25T21:41:26+01:00 2018-11-25T21:41:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40435#p40435 <![CDATA[NOundo 0.343 release]]> Statistics: Posted by joffo78 — 25 Nov 2018, 21:41
2018-11-25T18:10:20+01:00 2018-11-25T18:10:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40434#p40434 <![CDATA[NOundo 0.343 release]]> I'd like tu use it with Lemur on Ipad.
The connection between Lemur Editor and Lemur on Ipad is ok but I don't success to connect Lemur to Usine.
I didn't find in the Noundo guide, in the Lemur User Guide or in the Lemur IAE guide. How do you do?
Thanks again
Statistics: Posted by gwennaelle — 25 Nov 2018, 18:10
2018-11-24T08:50:46+01:00 2018-11-24T08:50:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40431#p40431 <![CDATA[NOundo 0.343 release]]> Statistics: Posted by senso — 24 Nov 2018, 08:50
2018-11-24T00:08:34+01:00 2018-11-24T00:08:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40430#p40430 <![CDATA[NOundo 0.343 release]]> Statistics: Posted by joffo78 — 24 Nov 2018, 00:08
2018-11-23T16:48:00+01:00 2018-11-23T16:48:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40429#p40429 <![CDATA[NOundo 0.343 release]]> Noundo seems nice but with Usine Hollyhock 3.0, I can't open it because "Noundo has been created by an earlier version of Usine. Usine cannot load it. Please update it." (Noundo a été créé par une version antérieure d'usine. Usine ne peut le charger. Veuillez le mettre à jour.)
What is the good version of Usine tu use it? Thks
Statistics: Posted by gwennaelle — 23 Nov 2018, 16:48
2018-11-21T19:13:23+01:00 2018-11-21T19:13:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40415#p40415 <![CDATA[NOundo 0.343 release]]> Statistics: Posted by senso — 21 Nov 2018, 19:13
2018-10-26T09:34:22+01:00 2018-10-26T09:34:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=6305&p=40301#p40301 <![CDATA[NOundo 0.343 release]]> http://www.sensomusic.org/downloadaddon ... elease.zip
A powerfull looper machine with à lot of fonctions.
Enjoy ita
Statistics: Posted by joffo78 — 26 Oct 2018, 10:34
Thanks again
Enjoy ita
