ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2019-03-26T08:08:04+01:00 https://brainmodular.org/forums/app.php/feed/topic/6304 2019-03-26T08:08:04+01:00 2019-03-26T08:08:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=6304&p=41050#p41050 <![CDATA[usine hollyhock 3.0.180 update]]> try to use the support@sensomusic.com next time, it's the best way to communicate with the team if you have troubles.
Statistics: Posted by senso — 26 Mar 2019, 08:08
2019-03-26T01:57:47+01:00 2019-03-26T01:57:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=6304&p=41049#p41049 <![CDATA[usine hollyhock 3.0.180 update]]>
I still have the old workspace that shows the problem but it is too complex to use as a test case, and if I simplify it too much the problem goes away. I did notice that when the problem occurs, the Paint() routine is called an extra time, but the Rect and font size passed to sdkFillText() were the same.
It seemed rather a coincidence there was a fix in the first problem Usine release 3.0.180, "GUI design for long patch's captions". Perhaps there is a minor backward compatibility problem.
Anyway since my new workspace is OK I will not investigate this any further.
Simon.
Statistics: Posted by sm_jamieson — 26 Mar 2019, 01:57
2019-03-24T23:30:39+01:00 2019-03-24T23:30:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=6304&p=41048#p41048 <![CDATA[usine hollyhock 3.0.180 update]]> Statistics: Posted by oli_lab — 24 Mar 2019, 23:30
2019-03-24T18:25:50+01:00 2019-03-24T18:25:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=6304&p=41046#p41046 <![CDATA[usine hollyhock 3.0.180 update]]> support@sensomusic.org
Statistics: Posted by nay-seven — 24 Mar 2019, 18:25
2019-03-24T17:43:43+01:00 2019-03-24T17:43:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=6304&p=41045#p41045 <![CDATA[usine hollyhock 3.0.180 update]]>
I note the fix:
GUI design for long patch's captions.
I don't know exactly what this fix is, but I am finding the size of text drawn with sdkFillText()
is inconsistent and sort of "wobbling" sometimes when the mouse is pressed.
Has anyone else seen anything like this ?
Simon.
Statistics: Posted by sm_jamieson — 24 Mar 2019, 17:43
2018-10-25T18:05:39+01:00 2018-10-25T18:05:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=6304&p=40300#p40300 <![CDATA[usine hollyhock 3.0.180 update]]> Statistics: Posted by x.iso — 25 Oct 2018, 19:05
2018-10-25T16:54:07+01:00 2018-10-25T16:54:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=6304&p=40299#p40299 <![CDATA[usine hollyhock 3.0.180 update]]>
improvements
- GUI design for long patch's captions.
- Settings_panel is now displayed in single column.
- Better drop items mode in the grid_panel.
bugs
- Midi learn on the presets_panel combobox are not saved.
- Once-in-poly doesn't work for color-input.
- Video-geometric-resize can crash memory.
- Data-mix-mixer module doesn't work properly when mix-values=0.
- Potential hard crash of Usine when BLOC size > 128.
Statistics: Posted by nay-seven — 25 Oct 2018, 17:54
Simon.
I note the fix:
Simon.
improvements
bugs
